![]() | Home > In Car Electronics (L405) > Speedometer Display |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1091 ![]() ![]() ![]() |
It’s in the display settings menu. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
you can also keep the digital display as mph to correspond to the main kph speedo. ... - .- -.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8108 ![]() ![]() ![]() |
I didn't realise you could change the main display - I always just change the digital readout to kph.
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 300 ![]() ![]() ![]() |
Thanks for the replies.
Menu button on the steering wheel ?
Hi Alistair
Hmmm - probably not helpful, but this is what mine shows -
OK, I don't have that at all. This is all I have
is it the same with the engine running Ivan?
Hi Stan
Ivan, your car is a launch spec 2012 build (it has blue rings around the speedo) yours uses the Range Rover logo in the centre of the binnacle, yes?
Hi Craig
Yep Nov 2013 for me - well done Craig |
Ivan, alas the canbus on your cars binnacle is different to that of Alistairs car so as far as I know there is NOT a software update to allow this to happen! Changing the binnacle’s could be an option? Maybe? Don’t know anyone who wants to go to that much work/expense to try sir… |
