![]() | Home > Maintenance & Mods (L322) > IID Tool not doing what's expected |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 547 ![]() ![]() ![]() |
I don't think it's a problem with the tool - the suspension needs to be in normal mode to calibrate.
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
When entering calibration mode on the tool the message not in customer mode appears.
Well it's your call but I would try toggling the build mode as I suggested and see whether it's set correctly. I had all sorts of weirdness on my D3 when the build mode was set incorrectly. 2016 Skoda Octavia VRS Estate
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 796 ![]() ![]() |
Check it’s not in tight tolerance mode as well |
This tool is starting to get on my nerves now.
Video of the oddness
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1053 ![]() ![]() |
You have accidently reversed a height sensor or both a common mistake when you disconnected then to change the lower arms.
I thought that but drivers side adjustment arm can only go one way. Passenger’s side is a mirror of the driver side.
Take a photo of you height sensor and I will compare it to mine |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 342 ![]() ![]() |
You would be better talking directly to Pat at Gap. He is the Chief Engineer and excellent, he just solves problems.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364 ![]() ![]() ![]() |
I would have thought that if your old arm bushes were really worn the new ones have pulled the hub into it's correct position which will have altered the tracking making your steering wheel not straight. |
Managed to get the suspension calibrated this morning, from cold- Result.
