![]() | Home > Maintenance & Mods (L322) > Rear hub/knuckle question |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
May be worth talking to one of the site sponsors, plus the advanced factors site has some handy drawings showing part numbers for various models, that may help you, a quick look shows similarities, |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 712 ![]() ![]() ![]() |
I've never heard of a worn knuckle causing new bushes to be loose & they are all the same !
Classic888 Member Since: 10 Jun 2015 Location: East Yorkshire & Hertfordshire Posts: 233 ![]() ![]() |
Apparently the following applies
Ben84 Member Since: 13 Dec 2018 Location: Cornwall Posts: 88 ![]() ![]() ![]() |
Thanks for all the advise, the garage will removing
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 343 ![]() ![]() ![]() |
I did mine a few weeks ago…. And then did them again the day after, this time using genuine parts, as the first attempt by using non-genuine rose joints ended up with them moving as Ben84 describes. I thought the first attempt went in too easily…… |
Before fitting new ones to my new front knuckles, I put the new ball joints in the freezer over night. They were still a good interference fit and took a while to bolt them in, but made fitting slightly easier. |
Fingers crossed the genuine bushes will sort my
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
Having recently done this job on My TD6 I cannot see how the new bush if correct can be loose in the hub carrier. They are a press fit needing a serious bush press to get them out and back in and are retained with a meaty circlip. Any wear on the old bushes would not affect the carrier bore as it would be inside the outer sleeve.
Genuine bushes have now been fitted.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8794 ![]() ![]() ![]() |
Result... |
