![]() | Home > Technical (L322) > L322 2012 Heated Seat Problems |
| RJPotts Member Since: 19 Aug 2021 Location: Durham Posts: 208
Not sure if the same process is used to test later vehicles but found the following at https://www.rangerovers.net/threads/heated...003.32026/
Do they work at all, even for a few seconds when first turned on? If the above doesn't give any pointers then the 2010-2012 workshop manual has quite a lot of info about how to test seat heaters. DM me an email address if you need the individual pdf. If all else fails then Abbey Auto Electrical in Sacriston seem ok, I've had a couple of minor things sorted on other cars there. Apparently they have the kit to diagnose / repair L322s. |
| BlackStang5point0 Member Since: 03 Sep 2021 Location: Co. Durham Posts: 14
Thanks for that I'll take a look.
I think I read somewhere that when seat functions go down because of a cracked duct that they work for a few moments, cant remember where I read that though.
| Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 |
Check out group buys?
