Home > Technical (L322) > 3 gang Pipe clips
landy95
3 gang Pipe clips
Hi all, i am currently on rust prevention on the second rear wheel arch and have broken one of the clips that hold the three air suspension pipes. Does anyone know where i can get these from? I have had a search on the forum and cant find anything. Also how does the tyre pressure sensor box come off the arch. Ive attached some pictures for clarity.
Cheers.
 Also own a 1976 Land Rover 101 3.5 V8.
Previously owned:-
2012 Range Rover Westminster.
1991 Range Rover Vogue 3.9 V8.
Post #608002 3rd Oct 2021 10:26am
landy95
Okay done some more searching, feel slightly foolish as i missed the parts catalogue Microcat in the wiki although i may be using the first microcat-english listed incorrectly as i could see the part but not a number, the last microcat english in the list showed the part number of the triple clip as RYC000110 and they aren't cheap at around £8 each.
Still not absolutely sure how the plastic box for tyre pressure gubbins is held onto the arch looks like a clip from microcat but not very clear.
Cheers. Also own a 1976 Land Rover 101 3.5 V8.
Previously owned:-
Post #608012 3rd Oct 2021 11:13am
kevinp
Have a look at part number SGK000050 mate.
Post #608013 3rd Oct 2021 11:15am
RJPotts
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
If that is the rear right side then is the box for tyre pressure sensors or for brake sensor plugs? I had thought the latter, unless there is a similar box close by.
Post #608017 3rd Oct 2021 11:38am
landy95
Im not sure which it is to be honest im sure someone will put us out of our mysery. Very Happy Also own a 1976 Land Rover 101 3.5 V8.
Previously owned:-
Post #608033 3rd Oct 2021 1:27pm
RJPotts
Just checked, its ABS and brake sensor plugs.
Post #608045 3rd Oct 2021 2:48pm
RichTD6
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
It’s a while since I had these off my TD6 to paint the wheel arches but if I remember correctly they are held on with two fir tree type clips which are moulded to the back of the box and you have to either push or pull a plastic pin from the centre of each plug to remove the box. You should be able to see them with the box lid open and the wires pulled out of the way. As I said though, it’s been a while and I may be thinking of the wrong bit, so sorry if I’m wrong! 2012 Westminster TDV8 4.4 Indus Silver
GAP IID Bluetooth Tool
Previous Range Rovers:
2005 L322 Vogue SE TD6 Zambezi Silver
1995 P38A HSE Epsom Green
1988 Classic Vogue EFi Cassis Red
1973 Two Door Tuscan Blue
Post #608143 4th Oct 2021 1:05am
landy95
Thanks for the info. Also own a 1976 Land Rover 101 3.5 V8.
Previously owned:-
Post #608527 6th Oct 2021 9:26pm
