![]() | Home > Technical (L322) > Airbox lid screws |
Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 105 ![]() ![]() ![]() |
Same guy must have been working on mine too |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
https://www.advancedfactors.co.uk/adv8796-...3630-p.asp
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
Brilliant Baltic - I've been thinking of replacing mine too |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
Found them too. At nearly £2 each. Jokes! |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1862 ![]() ![]() |
Cheaper from Jaguar |
The Jag part number is C2S11217
misfire84 Member Since: 25 Nov 2020 Location: brecon becons Posts: 37 ![]() ![]() ![]() |
RRDunc Member Since: 26 Feb 2020 Location: Leicestershire/Warwickshire border Posts: 520 ![]() ![]() ![]() |
You know that they dont have to come all the way out, don't you? As you undo them there's a point where they feel loose for a couple of turns. Stop there and they'll be free of the lower part and the upper part of the air filter box will lift up (when you've removed the other bits that are in the way on the nearside one!) and the screws are neatly in place for refitting. Dunc. The life you have is the only one you'll get; make the most of it. --------‐--‐-----------------‐------------------‐--------------------------------------------------- 2012 4.4 TDV8 L322 Autobiography 2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!) |
FYI - The genuine replacement ones are black, compared to the Jaguar ones which are silver |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
I'll go Jag and put up with silver |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1342 ![]() ![]() ![]() |
I suppose that if the screws have been damaged it at least shows the car might have been serviced at least once. But if they've ruined the screws how competent were they!! |
It is exactly the same part number. The bag has a Jaguar symbol on it. I ordered them from Jaguar, this is what has arrived. |
Here's a link FYI
