Home > In Car Electronics (L405) > Dadsh cam recommendations
goddo
As title suggests, what recommendations do you guys have for a dash cam in my L405. i am hoping it will sit behind/adjacent to passenger side of rear view mirror.
I have so far been advised that Next Base and Blackvue cameras are good but no model references.
Pros and Cons? Thanks.
Post #608334 5th Oct 2021 3:32pm
DrRob
Garmin Mini Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #608335 5th Oct 2021 3:38pm
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
I've used Blackvue in a couple of cars with no problems but there is now a LR branded cam that has good reviews - is a bit more expensive though. Part number is VPLKV0134 CTC had one fitted to his L405. 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #608337 5th Oct 2021 3:42pm
worth a look here,
http://www.techmoan.com/what-is-the-best-dashcam/ ... - .- -.
Post #608338 5th Oct 2021 3:49pm
Chalky
There is a problem with Low Battery warnings with the Blackvue dashcam. I had one in my 2018 car and was constantly getting the warning so switched off the Parking mode, which defeats the object of a dashcam!!
I now have the factory fitted LR cams which are brilliant and very simple to use with no issues whatsoever Thumbs Up Thumbs Up All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #608440 6th Oct 2021 10:10am
jez000
Did you fit the LR one yourself Chalky or get it done by the dealer ? 2021 P400 Silicon Silver AB
Post #608441 6th Oct 2021 10:13am
Snowy90 L322
United Kingdom 2019 Range Rover Vogue SDV6 Baltic Blue
[quote="Chalky"]There is a problem with Low Battery warnings with the Blackvue dashcam. I had one in my 2018 car and was constantly getting the warning so switched off the Parking mode, which defeats the object of a dashcam!!
I now have the factory fitted LR cams which are brilliant and very simple to use with no issues whatsoever Thumbs Up Thumbs Up[/quote
I have that same problem in my defender, battery protection doesnt seem to work ok if parked for medium periods but drains the battery if left for a few days, at the moment i just use a trickle charger. Not sure i would use Blackvue again]
Post #608448 6th Oct 2021 11:37am
Chalky
It was fitted when I picked the car up at my factory Handover day, but I think normally the car would arrive at the dealer from the factory and it would be a "dealer fit".
The only thing I would specify , had I known, is that the rear cam is fitted at the bottom of the window not at the top. It's not an issue anyway really as you hardly notice the cam when driving. Thumbs Up
There is a thread somewhere on here where Craig does a video of fitting it yourself, or maybe it's on Youtube? All LR cars from 1984
Post #608450 6th Oct 2021 12:09pm
jez000
Thanks Chalky Thumbs Up I'm probably going down the route of the LR one dealer fitted as long as my car gets built before they switch production. 2021 P400 Silicon Silver AB
Post #608452 6th Oct 2021 12:30pm
goddo
I have enough "Low Battery" warnings during the last year anyway and certainly don't want any more.
Good to know in advance that the park mode with these cameras does drain the battery significantly.
Post #608459 6th Oct 2021 1:27pm
knwatkins
DrRob wrote:
Garmin Mini
I second this, well, nearly - Garmin Mini 2. I installed one into my L405 recently.
£89 in Halfords at the moment.
A great, no nonsense review here...
 Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #608512 6th Oct 2021 8:18pm
bargain price here,
https://www.ebay.co.uk/itm/304147323210
Post #608524 6th Oct 2021 8:57pm
