Home > Maintenance & Mods (L322) > Sweaty Spare Wheel
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Sweaty Spare Wheel
Noticed this today - is it a case of 'they all do that sir'?
 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #608453 6th Oct 2021 12:31pm
Baltic Blue
I have just checked mine, it’s bone dry and dusty …. definitely not damp.
Post #608454 6th Oct 2021 12:47pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Unfortunately water ingress somewhere Big Cry
Post #608456 6th Oct 2021 1:13pm
Merchy
Must be water ingress, back on working on mine, been sitting on axle stands for 4 weeks, saw this and thought I had better check my spare - bone dry.
Post #608457 6th Oct 2021 1:15pm
DrRob
Check for water ingress. Lots of sources ...top tailgate hinges, tow bar bolts into x member, seals etc. It can take a long time to find. Be methodical.
Check behind the side covers to make sure no condensation on the electronics.
Lift spare wheel - any water sloshing about?
I use small pillows of water absorbing crystals to keep any small condensation at bay. Have 4 of them dotted around sides and wheel well. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #608458 6th Oct 2021 1:18pm
RR2B
No sign of water in the spare wheel well. Could the compressor be purging moist air creating a tropical micro-climate under the boot floor? 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #608487 6th Oct 2021 4:36pm
Unlikely to be down to the compressor, it doesn't usually work for long unless you have a leak.
If you have no sign of water collecting in the boot area the condensation could just be down to the weather conditions.
It's likely the wheel has got cold to a temperature below the dew point temperature of the air which given the amount of rain lately could be quite high.
If it's possible take the wheel out, dry it off and sit it somewhere to warm up.
The chances are that would resolve the problem.
If the condensation reoccurs you almost certainly have water sitting in the boot area somewhere.
Post #608491 6th Oct 2021 5:48pm
RR2B
I went for the cheapskate option!
TVR Griffith
Alfa Romeo Mito QV
Post #610580 27th Oct 2021 1:19pm
Highroller
Rolling with laughter
Post #610582 27th Oct 2021 1:26pm
