Home > Maintenance & Mods (L322) > DIY Headlining help |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
I have done plenty of headlining in the past including one on my TD6 with no sunroof. I plan to replace the cloth in my latest acquisition, a tdv8 with a Sunroof. Having read up in the workshop manual to find out about the sunroof area it refers to removing screws from the Roof Opening Panel Shield but that's it. it appears to be a link to Topix but I can't get access. Looks like the glass has to come out and a load of screws removed. Please, anyone, know the procedure? 2007 TDV8 VSE
8th Oct 2021 10:15am |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
I believe these are accessed with the sunroof open and from the top, looking down. |
8th Oct 2021 5:48pm |
Yes I get that, The panel has to come out to access the screws, What's the procedure to remove and refit. 2007 TDV8 VSE
8th Oct 2021 11:06pm |
Thanks, so no need to remove the glass? What about the sliding screen if I need to remove it to recover that? 2007 TDV8 VSE
9th Oct 2021 1:12am |
Ok I found this info on RangeRovers.net, hopefully, it might assist others in the future, as an ad in another post it says the slide can also be removed after the glass but no specific instruction
9th Oct 2021 1:51am |
Today I removed the headliner so whilst fresh in my mind here are a few ads to help.
12th Oct 2021 9:52am |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 220 |
watching with interest! mine will need doing soon! |
12th Oct 2021 10:03am |
I have done a few before and one in Suede. 1st time on an L322 with a sunroof. The local re-trimmers are not willing to do the job here in OZ, maybe I could get one to just recover it now it's out but I will DIY. It will be a week or so before I get the cloth delivered. 2007 TDV8 VSE
12th Oct 2021 10:16am |
Mine is a non sunroof so should be more straight forward.
12th Oct 2021 12:33pm |
Here is the link to my non-sunroof suede headliner post... https://www.fullfatrr.com/forum/topic33582...ner+option 2007 TDV8 VSE
13th Oct 2021 1:34am |
Thats some crazy headliner, very good look. and really good job.
13th Oct 2021 2:32pm |
Old foam comes off with a wire brush, it's tedious and messy but that's the best way I have found. The shell is quite tough, it is not damaged by the course brushing. I then paint over it with PVA to seal it and give a hard surface for the new glue.
13th Oct 2021 2:56pm |
I did the recover today, used spray adhesive after a few tests. Blown away by the result, really pleased with the outcome. Still need to do the sunroof blind but that will be simple.
19th Oct 2021 6:27am |
And here is the sunshade finished..
19th Oct 2021 7:25am |
