Home > Maintenance & Mods (L322) > Possible easy upgrade for High Beam Assist
Sonearly
Hoping this part also fits L322, it appears base part number is the same for L322, D4 and RRS
Post #601450 22nd Jul 2021 9:32am
GraemeS
Australia
Microcat 2012 it only shows this part# for the RRS. The L322 has various numbers depending on the door remote frequency, VIN and +/- Homelink. Also, the L322 has the ambient air temp sensor in the left side mirror.
Post #601456 22nd Jul 2021 10:21am
Sonearly
Ended up buying one from USA from 2011 L322, Easy install and set up with IID tool, very pleased with result and seems to being working well without upsetting oncoming traffic. Total cost including import taxes £82.
Post #608642 8th Oct 2021 2:34pm
mjdronfield
That’s good then. Nice little upgrade for not too much outlay.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #608644 8th Oct 2021 3:38pm
I can confirm the FFRR, RRS & D4 all use different numbered mirrors... Thumbs Up
Post #608671 8th Oct 2021 11:23pm
Sonearly
This was the one I used. Took onboard previous comments regarding different functions and bought one from L322 of the same age to be safe.
Post #608680 9th Oct 2021 8:10am
Ajmngn
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Is there any reason why a mirror with a slightly different engineering number won’t work. For example, I can get a mirror with number AH32176E678AD. It has the camera, but no home link. I’m not sure why the CAN messaging would be different as surely it’s all the same tech, I.e. the same camera and same control module inside the mirror? Andy
2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior
2017 Audi SQ5 3.0 V6T Quattro in Volcano Red
2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green (Currently SORN whilst undergoing some serious restoration!)
Post #705375 24th Nov 2024 11:44pm
Yes, a different number probably won’t work as it maybe for a Different marketplace? A different age? A different model? And yes, different age cars and different marketplaces have a different canbus protocol sir… Thumbs Up
Post #705391 25th Nov 2024 11:40am
Ajmngn
For wider awareness and in case anyone else tries to add high beam assist the part number ending AD mentioned above does work. I resolved my issue earlier after coding CCF differently. Apparently, you need to set the 2nd auto light option to ‘Disabled’ which is counter-intuitive, but worked. I picked up the tip from another thread which references yet another thread on the Disco3 forum. Spread the word! 👍 Andy
Post #705444 25th Nov 2024 11:05pm
