Home > Maintenance & Mods (L322) > FBH issues |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 841 |
You have selected the wrong heater type from the drop down list try going back over your settings |
5th Oct 2021 1:23pm |
colalowe Member Since: 11 Jul 2021 Location: Lancashire Posts: 104 |
Ah ok, I had selected Thermo Top C/Z BMW as that was suggested on most of the forums I had seen.
5th Oct 2021 1:47pm |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 292 |
Do you have IID? |
8th Oct 2021 10:06pm |
No, I just have the Webasto diagnostic software. |
9th Oct 2021 12:05am |
Follow this guide
9th Oct 2021 9:22am |
This evening I had a friend clear all the codes in the car, I didn’t see what the one for the fbh was unfortunately, anyway tonight I switched on the manual heat via the touch screen and the FBH fired into life, the pump was clicking and I could smell the fumes although I didn’t see smoke. The fuel pumped stopped after a couple of mins and the the FBH switched of shortly after.
10th Oct 2021 12:33am |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1463 |
Unless your 12v battery is absolutely top notch the FBH wont run for long. Mine was exactly like this, i proved it by running the FBH with a battery charger connected, it then ran on as it should, I fitted a new 12v battery and was greeted every morning with a nice warm car. BMW i3 Electric Car
10th Oct 2021 6:43am |
Sorry all, didn’t realise that I hadn’t posted an update for this, the problem in the end was the fuel dosing pump, even though it was clicking it wasn’t actually pumping any fuel to the heater.
4th Mar 2022 7:51pm |
4th Mar 2022 7:52pm |
