![]() | Home > Maintenance & Mods (L322) > hot rear wheel |
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
Definitely not a sticking calliper? Is one calliper hotter than the other? 1995 4.6 v8, green/tan (long gone)
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Depends on if you know the cars history mate. Can always take it to your local test centre and ask them to check the other side but generally for me as a rule of thumb, I'd change them both |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1342 ![]() ![]() ![]() |
I would say 100% sticking caliper. Get a cheap infra red temperature gun and point it at the disc and compare side to side. That's how I found mine to be sticking. Or go for a run, then jack it up and see if the wheel is stiff to move compared to the other side. Better still if you whip the pads out and see if the wheel then free's off. With the pads out check for any play in the bearing. |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Check the calipers first, when my rear ones seized the heat emitted was quite intense. |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 327 ![]() ![]() ![]() |
Went down to mechanic this morning and found that the caliper is the culprit.
