Home > Technical (L322) > 2010 5.0 SC Multiple warning lights.
Connor
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
Can anyone tell me what might be wrong, my Dad was driving and all these warnings appeared at once and the steering went heavy. We've only had it a few weeks and it has been faultless for 500 miles until now.
Heres a photo and a video
Post #608659 8th Oct 2021 7:30pm
Merchy
Never looked under the bonnet of an SC, but my 'guess' would be that a belt has failed, hence no power steering and the electrical / other faults because the alternator is no longer charging the battery ?
Someone with more knowledge should be along soon Thumbs Up
Post #608661 8th Oct 2021 8:05pm
Fox889
As Merchy said, if the belt's ok then everything points to the alternator.
Alternator & starter motor are notorious for failing before the 100k mark on these girls. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #608681 9th Oct 2021 8:15am
Connor
Thanks! Whats the best way to check if it's the belt?
Post #608707 9th Oct 2021 10:46am
The diesels eat starters and alternators, not so much the petrols...
Does sound like a belt though, just look at the front of the engine and see if you can see the drive belt going around all the pulleys
Check the battery voltage with the engine running, should be 14.2+ volts...
If the belt has gone the water pump won't be turning so don't leave it running too long...
Failing that you need some diagnostics plugging in to read faults and narrow it down... Thumbs Up Pete
Post #608713 9th Oct 2021 12:00pm
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
You should be able to spot if the belts are still intact. You don't need the engine running so if you're not mechanically minded don't have it running when you start poking about.
Get a torch and shine it down between the front of the engine and the radiator, tell us what you see.
Or take pictures. Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #608870 11th Oct 2021 6:12pm
Merchy
The belt winds it's way around several pulleys, so if you research this drive belt, it is sometimes called a serpentine belt, once you see it you will realise why, as in above post, for safety reasons, best check / poke around with engine stopped.
Post #608871 11th Oct 2021 7:03pm
