![]() | Home > Maintenance & Mods (L322) > Tailgate Rust Prevention |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1358 ![]() ![]() ![]() |
Just done my upper one mate. Remove the 2 screws in the centre recess first. Then lever the trim starting at one end. It's hard to get it started but then pops off quite easily. Once it comes away you have to pop the courtesy lights out and thread them back through the trim. Do the same with the emergency tailgate release lever. I had to replace 2 of the retaining clips on mine. |
Ricardo Villa Member Since: 01 Nov 2020 Location: Worcester Posts: 186 ![]() ![]() ![]() |
Thanks for tips, appreciated. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 397 ![]() ![]() ![]() |
just remove the number plate light strip no need to struggle with inside trim panel new vehicle purchase
That sounds easier, will hopefully get to everything from there. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
