![]() | Home > General > Does new EGRs on 3.6 TDV8 stop the risk? |
Klunk Member Since: 12 Jul 2021 Location: North wales Posts: 76 ![]() |
Interested in this also, it’s hard to get a definitive answer.
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
Its all a tough choice |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3308 ![]() ![]() ![]() |
Lowers the risk but not remove the risk as the turbos can be damaged due to other things such as a spit hose causing over spinning or lack of oil changes causing poor lubrication to the bearings. 2012 TDV8 Vogue (L322) |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7980 ![]() ![]() ![]() |
I think there tends to be more issues on the Sport as there is less room under the bonnet… so more heat…. But I’m no expert.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
I suspect most would/should have been replaced by now, we replaced them with genuine in our old car the second they started to misbehave when interrogated.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4342 ![]() ![]() ![]() |
Blank them physically and electronically. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 710 ![]() ![]() ![]() |
TJH1985, the big risk with the 3.6 EGRs isn't an electrical failure - that's just an an annoyance.
My point was that they would likely have been changed at least once, given my own experience of one failed electronically and the other very rough / worn mechanically. I stripped them down out of curiosity when I replaced them. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 786 ![]() ![]() ![]() |
When I bought my 3.6 2008 with 10000 on the clock 5 months ago, the first thing I did was blank them off and got them mapped out with a remap from quantum for £250 and it's well worth it. Many on here told me it's the best way as it reduces heat in the engine. I noticed straight away from blanking them off it ran much smoother and pulled better and even more so when it was remapped. Like others say, oil and filter change every 5000 miles without fail should prolong the turbo life and the engine. I've actually got in the habit now of checking hoses and sensors every week as a matter of preventative maintenance. |
