Home > Maintenance & Mods (L322) > Rear Brake Mud/Dust Shields Corroded
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi,
So I had a metal on metal grinding noise suddenly start the other day at the rear and it's the drum brake retaining pin dropped inside the shield where the dust shield has corroded.
Is there a part number for the shields (might as well do both sides) and somewhere that does them cheaper than other places ? I noticed that someone had one that was a slightly different shape, so you didn't have to get the grinder out and cut a bit of metal off, is there a part number for that one? (I'm not going to remove the hub).
Cheers for any info Thumbs Up
Post #609052 13th Oct 2021 6:45pm
They do pattern ones on eBay... a lot of the online spares places do them as well... you have to cut them in half and then weld or rivet them back together if you don't want to take the hub off unless someone has done a two piece one... needs lots of googling.. Thumbs Up Pete
Post #609107 14th Oct 2021 11:53am
batfink
Thanks Pete, just been Googling it and I see that I will need to cut in half and then rivet together as best option
Thumbs Up Thumbs Up
Post #609109 14th Oct 2021 12:06pm
You have to make some tabs to rivet the two sides to each other, you also have to make sure the shoes don't rub against the rivets, so some planning with positioning is required... I'd use some polyurethane sealer as well just to help out... then paint all raw edges... I did it on my old fatty, it wasn't too bad a job... get a shoe fitting kit with new clips and springs as well... Thumbs Up Pete
Post #609115 14th Oct 2021 1:32pm
Oh, and remember, one side at a time for when you forget what goes where..!! Pete
Post #609116 14th Oct 2021 1:33pm
batfink
Thanks Pete.
I found this very good overview of the process: https://www.rangerovers.net/threads/l322-r...to.268162/
And it included some really good pictures:
Post #609140 14th Oct 2021 4:21pm
batfink
I'm just waiting for Duckworths to get back to me with a price for the shields, but good idea about getting the other bits at the same time.
Post #609142 14th Oct 2021 4:23pm
batfink
So I finally got round to fitting the new back plates. The old ones weren't actually that bad, but had rusted through enough for the brake pad pin to pull through.
Anyway, all sorted now.
Post #615170 7th Dec 2021 1:44pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
If anyone's doing this there is another way too rectify it. Order yourself a brake shoe fitting kit, preferably one that comes with the pin washer plates, angle grind the securing hole slightly wider so the brake pin fits through, place on the back of the brake dust guard, refit the shoes and push the pin through, jobs a goodun.
Obviously this is only a temp repair till the dust shield gives up completely but will get you through a while
Post #615177 7th Dec 2021 2:05pm
