Home > Technical (L322) > HDC Fault - System Inactive - a new dreaded BONG
GrunterNI
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Well folks, another day another adventure in RR ownership Rolling Eyes
So.... for the past week or so Ive been getting an Air Suspension Fault bong at some stage almost every day. Once the ignition is switched off it usually clears itself and Im able to lift or drop the suspension and all appears well again, although when lowering height the suspension will nearly always revert to Extended Mode telling me to clear obstacle before allowing me to drop it to road height again.
Today however, all was fine until I called in to get it washed and freshened up. Now this may just be a coincidence, but when I got home 10 minutes later and went to reverse in to park I got another bong only this time the dash message was HDC Fault - System Inactive along with an amber exclamation warning light and an amber traction control warning light and I can now do nothing with the suspension. It also appears to be sitting higher than normal, the engine cooling fan is constantly running when the ignition is switched on and when I switch it off and get out I can hear a squeaking sound five or six times coming from the drivers side front wheel arch, something which Ive never heard before.
Can any of you knowledgeable folk tell me what causes the HDC warning, do I need it diagnosed to resolve it and could it be anything to do with the height sensors as these were the next items to replace on my list as the suspension has always been temperamental since I bought the car a year ago.
As usual any and all advice is greatly appreciated Thumbs Up Current collection :
2007 Vogue TDV8 Stornoway grey, black on black
1982 JCB Sitemaster (resto)
1970 MGB
BMW R1200GS
Post #609043 13th Oct 2021 5:17pm
rjff
IIRC the cause of the car going to extended height when trying to lower is that it is taking too long and the car thinks it's on an obstruction. The remedy seems to be to check the exhaust silencer (filter) on the suspension compressor as it may be blocked, causing slow lowering. Drill a 2mm hole staight through it and try again.
I'd suggest try that first and then see what problems remain.
The other problems may clear but if not then it may be coincidental low battery. Check the charging voltage and battery condition and the connections to it.
HTH Cheers
Richard
Gap IIDBT
Post #609102 14th Oct 2021 11:10am
And don't forget most suspension faults are hard faults and need to be reset to clear the showing errors, not just fixed, so you may need a diagnostic tool that can sort out a fatty... Thumbs Up Pete
Post #609119 14th Oct 2021 1:50pm
Snowy90 L322
United Kingdom 2019 Range Rover Vogue SDV6 Baltic Blue
First off as suggested check the battery is charged low battery sends out all sorts of spurious warnings.
However, when mine did this exact same thing, it was the steering angle sensor that had worn and stopped doing what its supposed to. Its a doughnut shaped thing that sits around the steering column under the dash tells the ecu which way the wheels are facing, its a Censored to change but that sorted mine. For some reason it renders the air suspension inactive.
Post #609120 14th Oct 2021 2:06pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Check for vacuum leaks too. PCV valve and the vacuum tube to the brake booster.
Post #609122 14th Oct 2021 2:18pm
GrunterNI
Thanks for all your replies guys. It really is appreciated Thumbs Up
The battery was only replaced 12 months ago and is reading 12.7V not running and 14.4Vish running so Im gonna discount that.
I take it the exhaust silencer is the little brass coloured cone on the compressor? Ive removed that and air moves through it freely. As you look at it in situ theres a hole through it top to bottom. Would that have been there originally or has someone already been in there and drilled it?
To save a lot of future poking about and guess work I'm gonna ask Santa for an IID tool but for now I'll just pay the £45 and book it into my local indi for a diagnostics report and fault reset next week then get anything faulty sorted then move onwards to the next RR challenge. Might get him to remap it when Im there......just dont tell the wife Whistle
Can anyone recommend where to get the replacement height sensors from and is it best to refit LR's extortionately priced originals or will after market sensors suffice? What about Ford, BMW or Jaguar? Any of their sensors do the job?
If it wasnt for the fact that I love driving the beast Id park it in my field and treat it to a gallon of petrol and a match Twisted Evil Current collection :
1970 MGB
BMW R1200GS
Post #609141 14th Oct 2021 4:23pm
vs322
Don't cheap out and use a flare instead. You're welcome Laughing
Seriously though, get the IID. It's worth every penny Thumbs Up
Post #609181 14th Oct 2021 6:40pm
Clobski
United Kingdom 2010 Range Rover Autobiography 4.4 V8 Baltic Blue
I’m just about to buy a Gap Diagnostics IID tool.. does any one know if there is a forum discount code or anything similar?? 2010 RR 4.4tdV8 Autobiography
1966 Series 2A 2.25 Petrol SWB - Sold
Post #609190 14th Oct 2021 7:29pm
rjff
Hi Grunter
Yes the silencer is the brass bit and it does appear someone has done the mod earlier Sad
The voltages look fine and sorry to not be more help.
The iiD is the way to go and I'm going to leave sourcing sensors to more knowlegeable folk who'll be along. Cheers
Richard
Gap IIDBT
Post #609220 14th Oct 2021 10:34pm
maric995
Croatia 2006 Range Rover HSE 4.4 V8 Zambezi Silver
For the height sensor I used OEM replacement (not original lr but looks identical) from island 4x4, and it works great Smile RR HSE 4.4 2006 LPG
Post #609228 15th Oct 2021 7:27am
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
i need to save this info
thanks every one RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #609384 16th Oct 2021 3:22pm
