![]() | Home > Technical (L322) > Electric Thermostat |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1582 ![]() ![]() |
The thermostat has a wax section that is heated by an electrical element to allow the thermostat to open further. Corrosion caused by leaking coolant where the electrical plug connects causes the wiring to go open circuit thus triggering the fault.
staffs964 Member Since: 21 May 2016 Location: Ontario, Canada. Posts: 11 ![]() ![]() ![]() |
Thanks for the response Ron and duly noted.
Sorry, I should have made it clearer. It’s the engine coolant thermostat.
OK Thank you, Ron
It seems you are confusing the engine temp sensor with the thermostat. Ron B. VK2OTC
Ok
