![]() | Home > Maintenance & Mods (L322) > Deployable steps motor assembly |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 782 ![]() ![]() |
I'm not sure there is an easy way to get it out. When I replaced a broken bracket on mine I had to destroy (heat grinder chisel etc.) what was left of the bracket to remove the motor without wrecking it. I seem to remember reassembly wasn't too bad but I can't remember the details |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
Thanks for that, I’m beginning to think I might have to resort to that kind of measure to avoid damaging the shaft itself. Got - 2017 SDV8 Autobiography in Loire Blue
G3BML Member Since: 22 Jul 2021 Location: Glasgow Posts: 98 ![]() ![]() ![]() |
Just done this job two weeks ago. My motor packed in and needed replaced. Once you remove the 3 x 10mm bolts holding the motor onto the bracket and the Allen head bolt that secures the wedge key into the motor shaft, the motor should in theory slide out the bracket. Mine was seized in.. Would try and avoid hitting the shaft with a hammer, that’s where I think I went wrong. |
So how did you get it out? Got - 2017 SDV8 Autobiography in Loire Blue
I put it in a vice and hit it through with a hammer and a drift. But this ended up cracking the bracket which failed 2 mins later after fitting new motor. Had to take the hit for a new motor and bracket
