Home > Technical (L322) > Dipstick shows overfilled
Starberg
Sweden 2003 Range Rover Vogue 4.4 V8 Java Black
Just changed the oil in the engine (M62) and according to manual and rave it takes 8.5L when refilling. I put in 8L to start with but when im checking the dipstick its well over the MAX. Anyone else had this problem? Should i do as the manual and RAVE states and put in 8.5L or drain out some oil til the dipstick is on normal? L322 Vogue 2003
Post #609741 19th Oct 2021 6:14pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Hi
Your engine has quite a large internal surface area with many areas where oil can collect in small pools as
well as it coating the internal surfaces. I normally leave it to drain for about 10 - 30 minutes with the oil hot after a run.
Personally I would drain a small amount off until its on max / normal (assuming the car is on level ground).
Post #609745 19th Oct 2021 6:41pm
