![]() | Home > Technical (L322) > Heater not heating at all!! |
| umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433
Oops smt not right with mine.
I had some leak due to my mistake so i deleted the post sorry... 2010 3.6tdv8 180k km.
I connected all hoses on the replacement valve with a T connector.
| Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804
Great news at last!!!!
I'm just doing a little bit of double checking myself, as there are two plunger seals in the valve. There is the one that you can see in your photos, the one that was swollen and you flattened, then there is one in the bottom of the valve.
Ideally you want to get a repair kit like this, with two rubber seals, o-rings and membrane seal. You don't need the plunger, as yours will be different to those shown on the kits and your plunger should be okay to reuse.
Probably it is pinned inside each other and they are pretty welded.
Hi again.
Is it normal that the turbo hoses are cold?
It shouldn't cause any problems leaving the tee piece connected as you have done, you don't need to blank off any lines as the coolant will circulate normally round the system, regardless of the bypass of the valve. The only difference in blanking the FFBH return line into the valve will be that all the coolant circulates through the engine.
If you feel the need to blank off any line, then blank off the top left hose into the valve, as shown on the picture and connect the hot coolant line from the engine into the outlet line from the valve.
Yes those two.
| All times are GMT |
