Home > Technical (L322) > Bushings and Arms |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 662 |
I always worry about ebay suspension stuff unless it's a known make and/or supplier. If you can guarantee the quality off the "net" then fair enough.
19th Oct 2021 8:24am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4225 |
Advanced Factors 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
19th Oct 2021 8:43am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
Depends how long you plan on keeping it....
19th Oct 2021 9:40am |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1490 |
With age etc if I was keeping it I would f#£k bushes off and change arms with new bushes, used Delphi in the past with good success. Lemforder also decent. I recently changed the upper and lower rear hub bushes using a dedicated bush removal kit.
21st Oct 2021 12:18am |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 220 |
As said before, if your keeping it avoid unbrand stuff, these cars are brutal on bushes and will chew threw anything other than OEM apart from i guess polybush etc.. |
21st Oct 2021 9:17am |
DeeJay Member Since: 16 Oct 2021 Location: Western Cape Posts: 34 |
I suppose that a special car deserves special care, this one is still special - Im not quite sure its reached a point in its life where i can afford to fit a part that will do the job for one trip once a year. This is a working car. So thank you for pointing it out along with other responders, and will have to pay special attention to ensure I source quality parts. 2011 Vogue SE 4.4 TDV8 |
21st Oct 2021 11:14am |
