![]() | Home > Maintenance & Mods (L405) > Service after only 2000 miles?!?! |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1377 ![]() ![]() |
If the car was serviced at a LR dealer, I would rule out wrong reset procedure, they must do dozens each day. But you can always contact them and get them to test for oil dilution or check ODB2 for the number of missed regenerations, which would be a good pointer to oil dilution.
scotsjon Member Since: 02 Mar 2021 Location: highlands Posts: 44 ![]() ![]() ![]() |
Great reply and thanks for that.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
I thought the unburned fuel entered the sump every regen, why would the unburned fuel enter the sump when you stop the engine mid regen? BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
If you have a successful uninterrupted Active Regen all the fuel used to increase the DPF temperatures is used up in that process, burnt and blown out of the exhaust system etc.
Thanks for the reply Kot, I'm not sure I can see how unburned fuel in the exhaust can make back to the sump?
Exhaust is the moment the gasses start leaving the cylinder during the exhaust stroke, maybe you misunderstood my post? or not understood my reply?
This issue is getting interesting for me now. After I had the car serviced on the 1st of this month (free of charge) I’ve been monitoring the mileage and length of time (miles) until the next service is due, the results have been surprising…
I have MY18 4.4
scotsjon
That’s very interesting, I’m looking at a very similar figure re the miles achieved between oil changes.
I got the car scanner app, plugged in a scanner and went for spin.
scotsjon good to see you have it working.
jtq4u Member Since: 23 Aug 2023 Location: Portsmouth Posts: 37 ![]() ![]() ![]() |
I just wrote to scotsjon on here as I am joining the oil change frustration group |
