Home > In Car Electronics (L322) > Begging for help ( audio )
Dacton
2006 Range Rover Vogue SE Td6 Baltic Blue
Hi all I appreciate any help it’s driving me crazy!
I’ve rung About 10 different audio repair experts and been told to Censored off.
It’s the logic 7 system with the black back amplifier
‘My 2006 Range Rovers audio is intermittent at best, I have no volume control through steering wheel, power button does nothing, no secret menu.
I’ve got the Bluetooth blank and I’ve checked for moisture and the only thing that seems to have any issue is the tv tuner, amp seems like there is no corrosion at all on it.
It will work for maybe 5-10 minutes then orange flashing light and no audio at all until left for multiple hours and then it’ll work for 10 minutes, I’ve also tried blanking the tmc to no avail and tried all fuses
Thanks for literally any help, it’s making me want to sell the car which is ashame because I love driving it.
Post #610049 22nd Oct 2021 1:58am
Fox889
Well, I know absolutely naff all about the electrics on here, but i'll give my two'pennyworth.
Change the head unit first? These are the same as the X5's? Reason I say that is, it gives you more scope for a decent used one off the 'net.
I'll give you an ignorant guess, it's either one end or the other, so head unit or big black box of tricks in the boot?
After reading this you'll probably wished I kept quiet. Rolling with laughter 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #610053 22nd Oct 2021 8:15am
I recommend you give yourself some time. You will need to remove all the modules from the rear of the car, dismantle each one so that you can check the circuit boards (PCBs) for corrosion/water ingress. Give a good clean with electrical contact cleaner and a toothbrush or similar soft brush. Also check all the contacts in the connections. Then see if that has helped. .
Post #610062 22nd Oct 2021 10:14am
Dacton
I have now stripped the rear amps and checked the PCBs, tv tuner has abit of corrosion on it rest is clean I have found some droplets of moisture on the floor, might send the amp off to be tested by a independent shop and not tell them it’s a Range Rover lol
Post #610068 22nd Oct 2021 11:59am
Baris used to be a good guy to deal with on these things. He put a bluetooth module in mine. Still didn't drown out the noise of the TD6 though. Laughing
It was a few years ago but would recommend him.
http://www.carphonics.co.uk/
Post #610071 22nd Oct 2021 12:39pm
Dacton
Baris won’t touch it Surprised
Post #610313 25th Oct 2021 12:30pm
mjdronfield
Baris specialises in the earlier BMW based non touchscreen system.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #610315 25th Oct 2021 12:41pm
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
Whereabouts are you?
Post #610316 25th Oct 2021 12:43pm
Dacton
Makes sense… I’m in Bournemouth, Dorset but willing to travel to sort this out
Post #610329 25th Oct 2021 4:23pm
Sorry, my mistake. I thought you had the earlier BMW stuff.
Post #610338 25th Oct 2021 5:54pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
I'd say best way you'll be able too get to the bottom of this is find someone who's got the spec motor with yours, offer them some wedge for the day and see if you can swap some of the modules, amp etc with a known working one. Least that way you'll be able too figure it out.
I'd hazard a guess going by your description it's more then likely the head unit with the no volume, screen etc
Post #610340 25th Oct 2021 6:19pm
