![]() | Home > General (L405) > Early L405 faults / problems |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8128 ![]() ![]() ![]() |
Ryan has a thread - https://www.fullfatrr.com/forum/topic44509.html
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 392 ![]() ![]() |
Hi, for what its worth, I purchased my 2016 SC in April 2019 with 17K miles. I just turned 34K miles. I have not had 1 problem. |
Boatmechanic Member Since: 11 Dec 2019 Location: West coast Posts: 95 ![]() ![]() |
Model year 2015 or later have most bugs worked out |
MonkeyMan Member Since: 20 Apr 2021 Location: Ascot Posts: 133 ![]() ![]() ![]() |
Honestly, if a 2013 model showed faults and bugs in the first few years, that’s a PITA for the original owner, but they should all have been sorted under warranty when they showed up.
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 301 ![]() ![]() ![]() |
Same as MonkeyMan above, mines a 2013 (2012 MY) Vogue SE one previous owner and had 85,000 on the clock when I got it last year. It's now just under 90,000 and (touch wood) have had no issues with it. I did notice that one recall was not done and that's where the rear spoiler rubs on the D Pillar trim. But, they are only minor marks so am not bothered.
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 256 ![]() ![]() ![]() |
I am the second owner of my 2013 with 160,000 km. I have replaced my DVD/NAVI unit due to the DVD player stopping (eBay $125) and the rear seat entertainment module due to one screen not receiving an signal to turn in (eBay $125-dealer paid).
Bmax01 Member Since: 04 Jul 2019 Location: London Posts: 76 ![]() ![]() ![]() |
Had mine since last Feb and has, touch wood, been more or less flawless. Buy a well maintained car, keep up with the service, drive it serenely and, save for wear and tear items (of which there are many tbf), you should be golden. Unless you're very unlucky, the main components are remarkably robust. L405 4.4 AB Loire Blue
tomo141 Member Since: 22 Aug 2017 Location: UK Posts: 96 ![]() ![]() |
I had a 3.0 2013 AB 13000 miles when i bought it 3 years old, Swapped it in March this year with 60000 miles. Had it 4 years with with LR extended warranty every year and not one claim. ------------------------------------------
GrandadRob Member Since: 01 Jul 2021 Location: North Herefordshire Posts: 242 ![]() ![]() ![]() |
I bought a 4.4 2013 about six months ago, 70k on the clock. As has been said before, no problems, just wonderful. Inspection revealed that two front brake pipes near to the wheels, show corrosion, not urgent.
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 461 ![]() ![]() ![]() |
I have a 97,000 2014 L405 Vogue SE. I am the second owner and a friend of mine bought it brand new - apart from routine maintenance items like bushes and tyres it has been faultless - ride improved considerably when LR changed the valve chest in the front suspension for the post 2015 type under extended warranty too.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1554 ![]() ![]() |
I’ve read a similar comment a few times … also commenting on the electrics being better. Just what were the issues that got worked out, or what makes the 2015 MY better ( beyond the emissions type stuff ) ? I’m curious as I’m strongly thinking of coming back to the fatty fold from my Evoque at the moment, but I would be in the 70k-100k miles 2013 - 15 range of vehicles. V8 or else ... |
2015 - 15 plate cars with dynamic response suspension (generally 4.4 TDV8) generally have the improved valve chest in the front suspension. I had my 2014 car upgraded to one of these under warranty. That improves the ride.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 672 ![]() ![]() |
By contrast I have a 15 plate EURO 6 MY16 with ~50k on the clock, and in the last couple of years and ~20k it has had 3 coolant leaks (thermostat housing, rear HVAC coolant pipes, one of the radiator hoses) the rear diff pinion was leaking so thats been done, restricted performance due to one of the exhaust temp sensors failing, both rear handbrake motors replaced as the casings were cracked and probably other bits.
