![]() | Home > Maintenance & Mods (L322) > Rangerover gearbox leaking when NSF wheel jacked up |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1023 ![]() ![]() |
The connector sleeve is at the rear offside of the transmission so that would certainly make sense.
tdv8rr2007 Member Since: 26 Oct 2021 Location: Yorkshire Posts: 13 ![]() ![]() ![]() |
Thank you Phil! Really appreciate your very detailed response and can see exactly what has happened now.....Do you fancy trying to sort out my clunky suspension next |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3269 ![]() ![]() ![]() |
Remember you need to drop the gearbox sump to change the sleeve. Would be worth getting new fluid at the same time. John
https://www.bristoltransmissionsshop.co.uk...t-22-p.asp
Yep, that’s a bargain - assuming the sump pan/filter is a genuine IBS Filtran unit (it says genuine ZF, so it should be).
Well its ordered so will update when it arrives |
Parts have all arrived and I have some time next week to crack on and get this done.
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
Is there not a manual in the ZF kit? My ZF8 kit came with a manual on how to change the oil. Christian.
Some info here:
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
Note found in ZF gearbox designers pages:
Cheers chaps!
Yes, the 6HP26/28/32 seals are all the same. You just need to be careful to avoid the equivalent 6HP19/21 seals, as they’re different.
Just wanted to say thank you to everyone who contributed to this post, I completed this job today following all the instructions and the car feels to shift so much better. Will double check the fluid tomorrow but am pretty sure that the job finished. |
