Home > In Car Electronics (L322) > Trailer led flash
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Trailer led flash
A bit confused but I think I am right that the bulb-out system caused the trailer leds to flash and can be turned off with diagnostics. What module controls this, LCM? Car is a 2007 TDV8. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #610711 28th Oct 2021 3:53am
I had to add ballast resistors to the trailer wiring - that makes them appear like bulbs to the car & the flashing works as expected.
Post #610757 28th Oct 2021 11:42am
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Correct mate. Best way is too add a pair of inline resistors so it fixes that issue.
Post #610987 29th Oct 2021 7:47pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
The resistors go in parallel to LED not inline (series). BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #610996 29th Oct 2021 8:24pm
wayneg
My led trailer lights work and the car does not show any problem. My issue is The bulb out system fire a 2volt pulse out to test the bulb and it causes a flash on the led. So the question is, can I turn off the cold test via diagnostics? If so which module has the setting 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #611015 30th Oct 2021 3:19am
AJGalaxy2012
I'm not sure on the Range Rover, on my Touareg with the diagnostic tool it was an option 'cold bulb test'. If it's not an option on Range Rover it wouldnt be difficult to add a resistor and capacitor combination to absorb the pulses and stop them displaying. BMW i3 Electric Car
Post #611016 30th Oct 2021 4:47am
