Home > Maintenance & Mods (L322) > Oil Cooler Filter Housing 3.6 TDV8 - Is there a gasket here?
Superspoons
Hi all,
Can anyone confirm if there is a gasket between the cooler and the 'base' of the Oil Cooler Filter Housing on a 2010 3.6 TDV8 as shown in the pic below?
I know there's one for the whole assembly, but I have a coolant leak at the back to the 'V' which I'm trying to locate. Thermostat housing replaced and the Hose Assembly/Hoses all checked and appear fine - pressure test next - but just wondered about the gasket.....
UPDATE:
I may have answered my own question ? Just found this image on Ebay and to me ... Id say there was something there ....
Thanks, Gavin Gavin
https://www.youtube.com/@ChallengingClassics
Post #610407 26th Oct 2021 11:59am
GraemeS
Australia
Yes there is a gasket but like the TDV6's cooler I haven't seen any reference for the gasket indicating that the gasket isn't available as a spare part, whereas the equivalent gasket for the 4.4's cooler is available as a spare part even though it wasn't initially.
Post #610484 26th Oct 2021 8:19pm
Superspoons
Thanks for confirming GraemeS Thumbs Up I asked Duckworth Parts this morning and yes, no gasket shown/available on Microcat.
I'll take it apart and take a look / reseal with an appropriate sealant. I've also just ordered LR002340 (the main gasket between the housing and engine) - there's really no point not doing it whilst I'm this far in and got it all apart.
 Gavin
Post #610561 27th Oct 2021 9:55am
GraemeS
Australia
When I changed my 4.4's gaskets I coated the new middle gasket with a high temperature silicone sealant. If your gasket doesn't disintegrate then perhaps that's an option for you.
Note that Microcat doesn't show the 4.4's gasket as a distinct item but now it is available so don't just rely on Microcat.
Post #610691 27th Oct 2021 8:29pm
Superspoons
Yes - I'll need to drop some of its oil and coolant though as I can imagine the two will mix if I removed just the cooler on its own.
I've bought some Granville Instant Gasket for this -
https://www.halfords.com/tools/garage-equi...TcEALw_wcB
I'm aiming to write this up for all fellow 3.6 owners who may need to do this in the future Gavin
Post #610726 28th Oct 2021 8:00am
jonminns
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
Pretty sure it’s 002342 - between the cooler and the base looking at the parts invoice from when I did this.
 2008/58 FFRR 3.6 TDV8 Vogue
Post #614813 5th Dec 2021 10:54am
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Hi Superspoons,
I know it's a few years ago but did your fix your oil leak, I have been trying to trace a leak from somewhere in the fuel/oil cooler or crankcase ventilation oil separator assembly area, I replaced the seals in the oil filter housing but there is still oil appearing.
I don't think it is the rocker cover seal since the oil is higher than the rocker seal and having taken the inlet manifold of twice now I wouldn't mind fixing it properly.
The problem is that the oil only appears when the engine is working, not something I can replicate in a garage, I'm thinking of somehow tying a mobile with it's video recording and going for a blast and hopefully not loose the mobile...
Will
Post #717891 13th May 2025 6:04pm
