Home > Maintenance & Mods (L322) > New rear bushes slipped!!
Henrik07
Norway 2007 Range Rover Vogue TDV8 Santorini Black
Hi all,
I recently replaced the rear upper knuckle-to-wishbone bushings on my '07 td8. The old ones were worn and had a lot of play. I forked out for a genuine set from Moog, part no. RHF000260. Inserting the new took less effort than pulling the old, but I did have to wind them in and it never struck me that the interference fit was insufficient. Now, both of them have popped out of their bores, rendering the car undriveable and dangerous.
Have anyone of you had this happen? My theory is that they have tolerance-issues at the Moog production facility or I was sent the wrong part.
Before you start pointing out the obvious: No, I did not sand out the bores to remove rust. I didn't even go near them with anything abrasive. I sprayed them with WD40 and pulled a rag through them, that's it.
Regards,
Henrik
Post #610902 29th Oct 2021 10:04am
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
I think you are correct regarding the fit. I replaced my upper knuckle joints with Lemforder ones from Duckworths (site sponsor) in 2016, the part number is:- RHF000260G. They were a very tight fit.
I also have the lower ones to fit, again Lemforder ones from Duckworths, the part numbers are :-
Lemforder 28882 01 / Land Rover part number :- LR032644G
Post #610919 29th Oct 2021 11:13am
Henrik07
Thanks!
I wonder if the "G" suffix indicates a larger diameter....?
Post #610923 29th Oct 2021 11:39am
Someone else had this same problem recently ( I can't find the topic).
Best to get your bushes from LR (Duckworths) by sending your VIN, to ensure correct bushes. They should be as tight going in as they were coming out! .
Post #610926 29th Oct 2021 11:53am
Henrik07
Joe,
Great to learn that I'm not alone. There must be something amiss at Moog. I have contacted their technical department for a statement, although I don't have high hopes. This could have been outright lethal if it happened at great speed, so maybe they should take an interest....
Post #610936 29th Oct 2021 2:27pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
Previous thread:
https://www.fullfatrr.com/forum/topic61066.html
Post #610939 29th Oct 2021 3:04pm
kevinp
I'm sure I've read that the 'G' suffix means genuine. Something like 'P' is pattern and so on.
Post #610943 29th Oct 2021 3:45pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Moog don't supply OE parts to Land Rover. They are an aftermarket supplier. Ditto Meyle
Beware some of the eBay ads for quite a few parts use rather "dodgy" wording - inferring they are genuine Land Rover, but if you read the ad carefully only means they are Genuine Moog or Genuine Meyle NOT Genuine Land Rover.
They're technically correct, but hoping you misread what it means Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #611004 29th Oct 2021 10:14pm
