Home > Technical (L322) > LHD Head Lights
Deep Down
France 2003 Range Rover Vogue Td6 Adriatic Blue
LHD Head Lights
Does any one know does the whole Lamp unit need changing to convert RHD to LHD head lights?
Post #61059 19th Apr 2011 10:46pm
daveo
i have had a few of these headlamps apart, if its not got adaptive you can adjust the light pod to point over to the other side, you will need to remove the headlight, so instead of the lights shinning to our left adjust them to the right, but if they are adaptive i think you will find the your ecu will centre them and then point them in the right direction according to your ecu V8 facelift Range Rover Autobiography 22" wheels.
Post #61066 19th Apr 2011 11:56pm
yours is 2003 so it has the square type light units and yep, you need new light units for lhd.. ... - .- -.
Post #61084 20th Apr 2011 9:22am
daveo
hi, my fault..i just took it you had 2006 lights,hence the adaptive reference V8 facelift Range Rover Autobiography 22" wheels.
Post #61093 20th Apr 2011 9:56am
dan_uk_1984
Do you not just flick the LHD/RHD lever over inside the lamp unit?
Post #61097 20th Apr 2011 10:00am
myvatn
Germany 2003 Range Rover Vogue 4.4 V8 Zermatt Silver
ours is a late 2003 RHD and you just have to switch (under the bonnet) the lamp unit to LHD to make it road leagl in mainland Europe
Post #61098 20th Apr 2011 10:05am
you can but it doesnt give a proper light distribution...thread on here somewhere re this..
edit..apparently the rhd lights point to the left and the switch just blanks the beam so it doesn't dazzle oncoming drivers. ... - .- -.
Post #61101 20th Apr 2011 10:08am
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
It isn't a simple as that I suspect - If the car is a UK registered LHD spec car then to pass the UK MOT you have to have the right pattern of beam spread and that requires a set of UK pattern headlights - the little lever is only meant for temporary use like going touring in Europe. Friend of mine has a UK supplied / registered LHD RRS in Belgium. It was supplied with the correct LHD dipping pattern headlights. Last year he had to bring it back to the UK for it's MOT and had to buy a set of UK pattern headlights to pass the MOT, luckily I was selling my bling set with the LED's in them so he collected them, fitted them (took 5 minutes) went for MOT and passed! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #61103 20th Apr 2011 10:19am
Deep Down
Did buy a 2003, but as the gearbox gave in after 25km, he got it back. In the middle of doing a deal for a 2004 after they went to touch screen. Given up on trying to buy an LHD model in good condition for real money.
Post #61131 20th Apr 2011 1:22pm
there are these two on ebay but they are very expensive and only halogen, and before you ask ,no they cant be converted to xenon..
http://cgi.ebay.co.uk/Range-Rover-L322-LH-...35ab35b887
http://cgi.ebay.co.uk/Range-Rover-L322-RH-...35ab35b94e ... - .- -.
Post #61142 20th Apr 2011 2:45pm
