![]() | Home > Maintenance & Mods (L322) > Bleeding brakes... |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Generally rears cause the problem.
Sleepy Jen Member Since: 15 Feb 2021 Location: Basingstoke Posts: 32 ![]() ![]() ![]() |
Thank you, I will have another try next weekend and let you know how I get on. |
Leigh4571 Member Since: 09 Oct 2021 Location: Shropshire Posts: 19 ![]() ![]() |
Hi, I have the same problem in a 2008 tdv 3.6. Replaced rear pipes and 1 front after much bleeding have a pedal that travels more than it used to, but stops the car, doesn’t improve with pumping, but when left over night will press to the floor.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic44822.html 2012 TDV8 Black Edition
My one has not been progressed any further, pedal has never reached the floor though. I did take it to a local LR specialist to check it out. They bled the brakes again and they said it was fine and don't worry about it... The car brakes perfectly apart from the pedal travel, I have wondered about fitting a new master cylinder in case an internal seal is leaking a bit, just a thought at this stage.
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 509 ![]() ![]() ![]() |
I bought one of these, easy to use, fill it with brake fluid, connect to master cylinder, pressurise to setting on gauge,
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
I replaced all my fluid using the two person pedal method, simplest way in my opinion.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
I've always gravity bleed the brakes on Fattys, works well, just take the top off the reservoir. Start at the bleed nipple furthest from the master cylinder...crack it open and wait.... after a few minutes brake fluid comes out, wait until you have a steady stream without frothing then close and move to the next, checking on the level at the reservoir.... It can take a while to come through if you changed a pipe but so far I've not had to use diagnostics to bleed the ABS pump, maybe I've been lucky....
You’ve got to be mega unlucky to for a master cylinder to fail when bleeding brakes but if it’s going to go then it would go anyway. I’d rather it fail on the drive when bleeding than when having to do an emergency stop.
Fair point, I imagine it depends a lot on when the fluid was last changed... my post is more tailored towards owners of older cars who are keeping them on a budget....
I always thought that the braking system was designed like that too but a friend of mine had a Mercedes E350 estate that went into Mercedes (somewhere near Potters Bar) to have some work done and they forgot to tighten his rear brake nipple and on the journey home he pumped out all the fluid and had brake failure on the M25 slip road up to the roundabout with Potters Bar turn off.
All modern cars, including fatties have split reservoirs, if the fluid drains out then it only effects two out of four wheels, unless you have multiple leaks which again is unlikely... you will need to press the pedal harder but you will stop.
Yes tandem brake circuits have been on cars since I can remember and I'm sure my friend embellished the story a bit, but so would anyone if they had a brake failure due to the main dealer's ineptitude!
Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 116 ![]() ![]() ![]() |
I have a vacuum bleeder. I think it was about £20 or so. Requires compressed air to power it. Works great. I think its really working along the gravity bleed route but with some gentle assistance. As well as working well it also doesn't allow fluid to get everywhere, so can be a very clean job, which is nice! My orgies of brake fluid with a Easibleed are long behind me!
