Home > Maintenance & Mods (L322) > Removable towbar - no keys!
MartinD
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
So, my car came with a removable towbar but no key - is the only solution to attack it with an angle grinder? 2011 4.4 TDV8 Vogue SE - 'Black Betty'
2000 4.0 P38 HSE - 'Green Goblin' - Gone.
Audi..Mini..BMW..
Post #611216 31st Oct 2021 8:41pm
Got any pictures ?
The genuine tow bar will unbolt from a little further under the car. If it's after market, then I guess it's grinder time if you just want it off.
Post #611218 31st Oct 2021 8:49pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
My genuine swan neck keys eventually refused to play. Ended up unbolting from the armature and keeping assembly in garage. Not as if many folk will do an off the cuff towing job. Looks a lot neater at the rear end too. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #611219 31st Oct 2021 8:55pm
MartinD
Don't think this one is a genuine LR one, but could be. Just defo don't have a key so I'll look at unbolting it I guess! 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #611231 31st Oct 2021 9:46pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Get it unbolted, down to a locksmith n see if they can make you a key
Post #611236 31st Oct 2021 10:38pm
MartinD
Wasn't aware that was a thing. Do you mean am actual locksmith or a place like Timpson? 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #611240 31st Oct 2021 10:48pm
mjdronfield
Errrr an actual real locksmith. A member of the Master Locksmiths Association should be able to make a new key…. Or pick it open….. or use a code stamped on the lock to cut a new key.
Some may even be able to cut one if you tell them of a code on the lock and post it out to you.
You might need to send them a pic or have a natter over the phone….
A decent one near me…
https://wgpollard.co.uk/
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #611241 31st Oct 2021 10:56pm
1. Show picture, we can then maybe identify make
2. Is there a code on the lock itself, with 1. above you can get a key made .
Post #611242 31st Oct 2021 11:06pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
If its a westfalia one some dealers have a full set of keys and can identify which one you need, or, I believe westfalia will send you a master set with a deposit for you try yourself. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #611249 1st Nov 2021 7:27am
Henrik07
Norway 2007 Range Rover Vogue TDV8 Santorini Black
I'm not sure this will work on yours, being none original, but here's the story: I drove off with the trailer hitch not properly engaged. First bump, the trailer came off and the security cable snap-lock disintegrated. On its way back, what was left of the hook smashed the plastic wheel you would turn and pull to undo the tow-bar, taking the lock out with it. This left a smaller 3-spoke metal wheel which can be grabbed with pliers, twisted and pulled and the bar comes off. No key needed anymore. So, if your aftermarket bar is the same design, taking a hammer to that wheel might do the trick. 😉
Post #611298 1st Nov 2021 3:02pm
KeithC
United Kingdom 2011 Range Rover Autobiography TDV8 Bournville
Perhaps not relevant if an aftermarket bar but I had a Westfalia with no key and stuck in the received. I removed the side plastic cover (opposite side to the handwheel) removed the circlip and drifted out the shaft 10mm. this allowed the handwheel to turn without a key. Took a bit of knocking back and forth to loosen the hook from holder as been there for a while but it came out.
I then bought a similar looking one with key off facebook (guy said it was off an Audi Q3 but I think anything Westfalia and similar looking will do) and had the guys in my workshop blast and paint the old one then change over the internals from the Q3 one to my original. Result, refurbished towbar with key for the £50 cost of the spare one. Thumbs Up
Post #611390 2nd Nov 2021 4:03pm
