Home > Technical (L322) > Change brake pad bolts, etc. when fitting new brake pads?
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Is it recommended that we fit a new "Brake Pad Fitting Kit Front - LR016683" when fitting new brake pads and discs?
I'm planning on replacing the disc retaining screws (SDG10000L) with the discs but wasn't sure about the above.
Thanks.
Post #611571 4th Nov 2021 12:55pm
4434Morrison
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
I recommend you have the pins available before you start replacing the discs and pads. When I replaced mine I didn't and the existing pins were seized solid and one was totally destroyed in the process of removing the pads. 2012 4.4 TDV8 Vogue SE Current
2015 E220 with AMG Sport Pack - Currently driven by my son
2010 3.6 TDV8 Vogue - Written off by my son
Post #611572 4th Nov 2021 1:00pm
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Bearmach do a brake pad fitting kit, it's a large pad retention pin with bolt securing and then two smaller pins which secure the anti rattle spring.
They will be destroyed upon removal, it's well known they cannot be reused.
This is how mine ended up.
This is what the kit contains
 Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #611578 4th Nov 2021 2:25pm
Range Rover L322
Is there a punch with an inverted conical end to push them out?
Post #611593 4th Nov 2021 5:41pm
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
Yes, in my toolbox! If you look on Ebay, one can find extended length Torx bits, I buy them and spin the end on a grinding wheel to dish the end. You might be lucky and find a set of Pin Punches someone is getting rid of. Make sure they are Tool Steel. Standard lengths of Tool Steel from an Engineering tool supplier like Cromwell should have what you want. Even a four inch nail can be helpful.
Post #611596 4th Nov 2021 5:59pm
