![]() | Home > Off Topic > Wet on inside of hall walls |
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 124 ![]() ![]() ![]() |
Hi Mr Blond!. Not enough information there. I built an eighty square metre extension in 2015, and the floor has four inches of polystyrene under six inches of concrete, the DPC is under the lot. Walls have a DPC jointed to the floor DPC two brick courses under the floor level. Have a look at whether you have DPC's, and at what level. Also make sure the walls are fully dried out, (three months), and you have no water leaks from pipes or radiators. Hope that helps. |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
Is the ground level outside higher than the inside? Is it a cavity wall or solid?
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1671 ![]() ![]() ![]() |
Dampness in any building is one of three things.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8059 ![]() ![]() ![]() |
Interior wall or exterior ?
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1401 ![]() ![]() |
I have an old house no cavity's and the joints are all lime mortar so its breathing lol
Andra Member Since: 22 Sep 2015 Location: Scotland Posts: 83 ![]() ![]() |
Photos may or may not help .
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 226 ![]() ![]() ![]() |
Damp coming through is likley to cause severe staining as it takes an age to coe through and brings with it all the colouration of sand plaster etc... If its simply like teh wall has been splashed its most likley condensation.
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
Late reply one and all, apologies but have been working away since before Christmas |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Yep, I think you probably have it spot on there. It’s amazing how much damp will occur in unheated recently renovated rooms. At a metre up it’s unlikely to be rising damp. That would usually start at the bottom. If it’s an external wall it could be penetrating damp, but again that’s fairly easy to rectify by seeing if there is an obvious pointing defect on the other side….
Put the dehumidifier next to it, you dont want the damp patch to grow mould as the spores can be breathed in and not very good for you.
Morning guys (rather s3xist assumption I know)
1930's house! with solid walls and no cavity, you need to check what mortor is used on the building of the house.
Thanks Kot - interesting point. I'm assuming its normal cement, is there any way of telling?
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 300 ![]() ![]() ![]() |
If the plaster is pink, then it's not correct. We used to own a house many years ago which had been refurbished. Unfortunately they used standard Carlite? plaster on the lower half of the walls. When we sold the surveyor raised a damp issue that was caused by them using the wrong type of plaster to repair the walls with. Basically it never dried out.
