![]() | Home > Technical (L322) > Electric thermostat circuit fault ***solved*** |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 615 ![]() ![]() ![]() |
M62 engine.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
Lots of info here, shows what a waste of time it is to keep it, does your engine no good at all...!! |
Thanks one more time, Pete. I'm aware of the mod and may in fact go for it eventually if this is proven to be the thermostat. I do prefer to keep my car in stock configuration but this mod indeed has its merits. |
The ONLY reason for the stock excessive heat was to pass emissions, nothing else, BMW never ran the engine that hot...!! Pete
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1579 ![]() ![]() |
I've done the mod. I'd like to knoiw what resistance I need to connect to the wiring to emulate the heater element and thus get rid of the fault code. Ron B. VK2OTC
Pleased to report that the issue has apparently been resolved. Disconnected the plug once again, soaked it in WD40 and gently pushed / bent inwards the metallic terminals on the plug to achieve a tighter fit. Squirted some more WD40 on the thermostat terminals as well.
