Home > Camping, Caravanning and Holidays > Any advice converting a US boat trailer to UK/EU? |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1193 |
Even if you only intend to use it occaisionally, I feel it may ba a rather complicated process if you wish to be legal on the road with a homebuilt trailer. If someting nasty happens, you may find a large book inbound at you.
7th Nov 2021 10:50am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1350 |
It wouldn't be a home built trailer. It would have braked hubs instead of the current un-braked and the coupling changed. 2015 Range Rover Autobiography 4.4 SDV8 |
7th Nov 2021 11:04am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7763 |
I'd also expect it to be cheaper to try to pick up a second hand UK trailer - there's usually plenty on eBay.
7th Nov 2021 11:07am |
In America, brakes aren't mandatory on lighter trailers so, the trailer is actually currently rated up to 1.6T un-braked. There should either be some braked hubs and I can buy and get fitted to suit these trailers (as they're pretty common in the US and the design has hardly changed in 25 years).
7th Nov 2021 11:13am |
I'm not a caravan expert - do they come with leaf springs ?
7th Nov 2021 11:18am |
I have grabbed some photos of the one which has been converted, which is exactly how you describe. It has had a non-original axle fitted to the leaf springs with welded on hubs, plus a 2nd hand coupling.
7th Nov 2021 11:22am |
Something like this - https://www.westerntowing.co.uk/product/al...to-1500kg/ |
7th Nov 2021 11:25am |
You probably already know, but the blue cables shown on your photos are like old push bike brakes - a cable inside a sheath. There's then an exposed cable to the hitch with is pulled by the hitch or hand brake.
7th Nov 2021 11:28am |
Gary
7th Nov 2021 12:32pm |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 922 |
Ultimately I think it's all gonna come down too how easy you want too make your life in doing the conversion as you'll have two options.
7th Nov 2021 1:05pm |
This is my thinking. I've got an existing fully galvanised heavy duty frame trailer with leafs, which bounce around no way near as much as the caravan type hubs with suspension - better than some of the cheap English trailers.
7th Nov 2021 1:52pm |
I think I'm over thinking it.
7th Nov 2021 8:28pm |
Personally mate I'd just get a whole new axle and coupling hitch. That way you know its all good for a few years and you won't be having to replace the shows, lines etc in 6 months time. It may well be a bit expensive for the initial layout but long term it will be the cheaper out lay.
7th Nov 2021 10:03pm |
It's a bit more expensive than that (unless you've found a really cheap site I don't know about).
7th Nov 2021 10:21pm |
