Home > Maintenance & Mods (L322) > L322 TDV8 EGR delete kit
Kevhdkent
I have viewed a number of posts with respect to the physical blanking of the EGR valves that do not require (but may benefit from) electronically mapping out.
Can anyone recommend a specific kit, and/or supplier please ?
(I’ve tried eBay, but might be using wrong search criteria)
Post #611849 6th Nov 2021 8:15pm
mjdronfield
3.6 or 4.4?
Much easier to do on 3.6 I believe.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #611850 6th Nov 2021 8:29pm
DrRob
My mate has a 3.6 kit for sale.
4.4 should not be blanked or your DPF will make you pay Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #611862 6th Nov 2021 10:32pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I just purchased and fitted these.. https://www.ebay.co.uk/itm/121107007210 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #611866 7th Nov 2021 12:34am
Kevhdkent
It’s the 3.6. My not be required as far may have passed away 🙁
Thanks Wayne.
I see you have a 3.6, and previously a TD6 3.0
How would you compare the 2 ?
My brief experience with the 3.6 V8 tells me they’re prone to issues and extremely check complex for a reluctant home mechanic.
Whereas the BMW straight 6 would appear less sophisticated and therefore less prone to malfunction and easier/cheaper to fix when they do.
Would that be fair ?
Post #611919 7th Nov 2021 6:51pm
mjdronfield
The TD6 is a very reliable well tested engine, but the gearbox is made of chocolate. It’s a much less modern engine than the TDV8, noisy and way less power. You need to drive one of each. TD6 wasn’t bad in it’s day…. I had one, but it’s old now.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #611920 7th Nov 2021 7:05pm
Kevhdkent
Post #611947 7th Nov 2021 10:45pm
wayneg
I had the TD6 for 6 1/2 years and have to say it was easy to maintain and cheap to run. I sold it for what I paid so almost free motoring. Apart from a test run before purchase the TDV8 has sat in the garage unused but yesterday became my daily driver and WOW the engine is so much more refined and of course powerful. The cabin is much quieter. As I did the EGR delete before really driving it I cant compare before and after but the wife said whilst following on the trip home there was a puff of black smoke on hard acceleration, now there is none. The tick over on the initial start-up was a little lumpy, now super smooth Time will tell on reliability, the TD6 never let me down and took me on some very long and remote trips 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #611950 7th Nov 2021 11:41pm
Re: L322 TDV8 EGR delete kit
If your looking at a car to maintain at home then of course the TD6 is easier. Find one with a fresh'ish gearbox then all the better BUT, buy a 3.6 that has had the turbo's changed and has a good history, you will be owning a jolly nice 322 sir... Thumbs Up
Post #611956 8th Nov 2021 12:51am
Champix
Spain 2009 Range Rover HSE TDV8 Barolo Black
With a small steel is possible to take away
Post #611957 8th Nov 2021 12:53am
