Home > Technical (L322) > Are my Starting problems simply down to my battery?
TeeMyob
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
https://www.fullfatrr.com/forum/topic60587.html
Back to the Start:
I replaced LR battery with Hankook Battery
Still had starting issues.
JLR said they could not fault the starting
Drove to Spain, starter motor replaced by local garage. Still not starting, they said it needed an AGM Battery. They fitted a Bosch S5 battery that I believe is not an AGM Battery.
Drove back to UK after having a new, battery and starter motor.
4 weeks later, went away. Wife moved car off drive, stopped and then it would not start.
My pal tried a jump start with leads to his van - no start
Breakdown man came, tried the same from his van - no start
Day after, recovery man came, he put jump leads on from his truck - STARTED
Took car for a drive out - parked up no start
Recovery driver returned next day - car started
Recovery driver loaded onto truck and drove to garage where it was driven off the truck
Garage - Started
Garage - not started
Garage replaced new starter with original starter
I drove to Tarbert in Scotland from Manchester
Tarbert Hotel - Started
10 min drive to Islay Ferry - Started
Check in Desk at ferry - 1st time clink / clunk 2nd time started.
Left the car running until boarded ferry
Disembarking Ferry - Started
Used car a couple of time on Island
Day before leaving, charged overnight with charger
Day of leaving - Started
Waiting to board - left running
Filling Station - Started
Hotel - Parked up
Leaving Hotel - failed to start (I had taken a spare Trojan battery and leads)
Jump started
Then after 3 hour drive from Carlisle, I put battery charger on at home. Voltage reads 12.4v but charger says only 25% charged
Im really fed up of this saga now. For what really is an amazing car to drive with a cracking engine. When it starts
Post #605278 31st Aug 2021 10:06pm
mjdronfield
Bloody hell….. other than checking all the connections, which must have been done…. There is only the alternator left, though I’m sure you will have checked it’s charging.
As you know, battery and starter appear to fix most of the issues.
Mine clicks sometimes…. Got a new JLR battery going on Monday… but I’m suspecting a starter may be needed in due course….
Sorry I’m not much help…
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #605280 31st Aug 2021 10:18pm
TeeMyob
14.7 volts when engine running
Thank you for the reply
Post #605283 31st Aug 2021 10:29pm
kevinp
When you say it doesn't start, does it actually turn over? I had a car that did that and it was a faulty crankshaft position sensor connector.
Post #605285 31st Aug 2021 10:47pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Given the fact that you've changed the battery and starter I'd be inclined to look at the ignition system. Could be something to do with the key not sending the correct info to maybe a dodgy earth strap.
Start with the free stuff like disconnecting the earth strap, getting a jump lead on it direct to the battery n see if that helps.
Been there before it intermittent starting so I know your pain
Post #605286 31st Aug 2021 11:17pm
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
I have had no starting issues since i cleaned and tightened up the electrical's. (still observing)
This particular nut was finger tight!! so worthwhile going through main distribution. Should have change these to nyloc.
The car is very power hungry, so a functioning charging system is a must. I found the car needs to be told when you replace a battery else charging will be erratic. This will lead to > battery drain > no start also SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #605288 31st Aug 2021 11:40pm
TeeMyob
Thanks @ffrr14 I can’t see that diagram very well. May I ask where battery box 2 is please ?
Post #605463 3rd Sep 2021 7:49am
ffrr14
It is behind the battery. The one marked was loose for me, but I removed and cleaned all of that and the box next to it as well.
Lookslike that circuit supply's the ECM :O SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #605471 3rd Sep 2021 10:46am
TeeMyob
Thanks everyone, my car is off the road again.
This time with another different Garage, A Range Rover Specialist.
He is suggesting the starter be replaced.
The one I had fitted in Spain only had 3.6 TDV* on the box
Post #612125 9th Nov 2021 12:52pm
DrRob
Get them to check, clean and test all the connections in the circuit from battery all the way to starter motor. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #612126 9th Nov 2021 1:43pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Dr Rob - beat me to it. Sounds very much like a connection issue than a component failure.
Post #612127 9th Nov 2021 2:36pm
TeeMyob
Thanks for the replies.
I have another new starter motor on now.
This one is a Denso,
Lets see what happens.
I had considered selling it. However. one of our daughters has boomeranged back from the middle east for 3 months and has commandeered it
Post #613355 21st Nov 2021 8:39pm
