Home > Technical (L405) > L405 FBH issue
Pat
Scotland 2013 Range Rover Autobiography SDV8 Causeway Grey
L405 FBH issue
Hi I cant get my FBH to work at all Fob flashes red when I try On iIID tool imgetting fault code B129A-88
Does anybody have any ideas what this means
TIA
Post #612134 9th Nov 2021 5:21pm
Fifth Horseman
The LED indicator signals various states and conditions for the heater as follows:
• Illuminates green when the ON button is pressed, then quickly flashes green to indicate that the heater operation has been requested.
• Illuminates green followed by red when the OFF button is pressed to indicate that the heater has been requested to shut down.
• Illuminates green, then quickly flashes red when either the ON or OFF button is pressed to indicate there is no communication with the receiver.
• Illuminates green, then slowly flashes red when either the ON or OFF button is pressed to indicate that there is an error.
• Flashes red when either the ON or OFF button is pressed to indicate the remote battery is empty.
The error code you are getting along with a flashing red LED suggests the FFBH heater fuse may have blown or a FFBH fault stopping communication between the FFBH and the ATCM. It could also be a wiring fault between the FFBH and the ATCM.
The FFBH fuse is in the smaller luggage compartment fuse box, position 16, 20A (yellow).
Post #612145 9th Nov 2021 7:21pm
154JON
United Kingdom 2015 Range Rover Vogue SDV8 Santorini Black
Have you had the FBH heater working before .
Post #612182 10th Nov 2021 10:35am
Dave G
United Kingdom 2013 Range Rover Autobiography SDV8 Indus Silver
Does it work from the screen? Might be worth a trying 1st?
Dave. 2013 Range Rover Autobiography 4.4 SDV8
Previous:
AMG C Class
AMG GLA
AUDI RS6
NISSAN GT-R x 5
Post #612213 10th Nov 2021 2:54pm
