![]() | Home > Technical (L322) > Scrubbed rears…. |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 712 ![]() ![]() ![]() |
It is adjustable, so you need to find another garage - lol.
Markwood71 Member Since: 19 Sep 2019 Location: Dudley Posts: 31 ![]() ![]() ![]() |
Hi Pawl,
Was it scrubbing badly before you had the rear arms replaced ?
aids22 Member Since: 10 Jun 2019 Location: Warrington Posts: 28 ![]() ![]() ![]() |
The camber also affects the toe.
Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 105 ![]() ![]() ![]() |
Curious to know how the type of engine induction has anything to do with this! |
The suspension settings are slightly different between the different engine variants - probably due to the engine weights differing Paul,
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4344 ![]() ![]() ![]() |
Nobody should be doing an alignment without first checking all bushes are not worn otherwise it's pointless.
Hi Dr Rob,
Rudyard1 Member Since: 15 Nov 2021 Location: Devon Posts: 105 ![]() ![]() |
I can see from the pic that you have Landsail tyres on - mine came with them and I too wondered about poor tracking etc as they were wearing badly/inconsistently.
UPDATE- Went to a Hunter approved Tracking garage. Explained the issues and they asked to re-track on their system to see for then selves. even worse on the rears. ( pictures to follow). They tried to adjust rear toe & camber but found both rear upper arms "un-adjustable due to corroded bolts) recommend 2 new rear upper arms, bolts washers & nuts. 4 hours labour later ( and a dremmel to remove the NSR bolts) all tracked and all within tolerance. I "think"- when the rear lower arms were replaced, they forgot to mark the bolts ( Pawl- you were right......) and when i was told they car had been re tracked, they maybe forgot to tell the truth...... all in all though- jobs a good un' and she now feels much more glued to the road. Welcome Rosie J - The Newer Kid on the Block RIP Rosie (We all Love Rosie - especially in S mode at the traffic lights) |
Before and after
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3327 ![]() ![]() ![]() |
It's a great feeling seeing all of those boxes going green whilst they're tracking the car!
Brilliant news! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Glad you're sorted! Paul,
