![]() | Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
| kansanbrit Member Since: 11 Nov 2021 Location: Kansas Posts: 4
Looks like he used a GAP IID to me. www.gap-diagnostic.com |
| TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 213
Getting that kind of weather now.
| Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701
Bite the bullet, get a new pettier unit from Duckworths on here & do the job proper |
Thanks
Site sponsors & they offer members a discount. Great service as well. Check one of my threads about 12 months ago, I had the same problem & cured it with a new unit. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
| JNC Member Since: 23 Feb 2020 Location: UK Posts: 293
We still have some repair kits in stock. Not many left. Will be placing an order soon.
| Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156
I used one of the kits provided by JNC and did the fix myself. It took me about an hour to disassemble the seat back, remove the failed unit, change the peltier cell and corrugated housing, replace the repaired unit and reassemble the seat back.
| G3BML Member Since: 22 Jul 2021 Location: Glasgow Posts: 98
Do you provide a kit that replaces the peltier cell on the seat base and backrest? Both my front seats don’t work at all.
I’ve never seen the base unit fail.
Don't if anyone has said this before but the same unit is used in 09-15 Jaguar XF seat. |
| RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 262
My seat back heats up, but not the base. Seems to be the opposite to everyone else? 2011MY 4.4TDV8 Autobiography Baltic Blue
| Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 |
It could be that the filter is blocked? |
| 28capridave Member Since: 08 Nov 2020 Location: stockport Posts: 36
Mine does exactly the same the base refuses to heat up but if i turn just the back on it works a treat have checked the filter and its clear the cooling works really cold its a 2012 model |
Does the system shut down if both parts are turned on?
