Home > Technical (L322) > Electrical gremlins ...please help !!!!
Spilly1978
United Kingdom 2007 Range Rover Vogue TDV8 Barolo Black
hi everyone, I'm hoping someone can point me in the right direction as no garage near me wants to take the challenge on ...
So my l322 tdv8 got caught in some really heavy rain and since then its gone haywire ...I've no interior lights , no central locking , can't open tail gate , no wipers, and messages telling me that suspension won't work unless doors are closed . But they are closed !!!.
I was told it was water somewhere so I looked under the passenger seat and it was bone dry , near the sat nav and wheel well again both dry .... I put a new battery on and I've touched both terminals together .I was told that the bcu may be down and that it is plug and play so I replaced that and still everything is the same .....I did notice my rear lense had condensation in it so I removed it and there was water in there so I empties it and cleaned everything up and put it back together but it didn't make a difference... is it a lost cause or can it be fixed ? Please help πŸ˜…
Post #612388 12th Nov 2021 10:50am
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
The body control unit needs to be programmed to your car mate so will need gap iid to make it work. That's probably going to be your next best move as those items that ain't working are very much bcu related
Post #612396 12th Nov 2021 11:36am
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi, that sounds like it’s dropped itself into transport mode. Use diagnostics like the Gap IID Tool to check and remove transport mode, if it is actually that. ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #612397 12th Nov 2021 11:37am
Spilly1978
Thanks for that guys ..... another problem I forgot to mention was that the obd port doesn't seem to work ...
A mobile fitter came to me as I can't drive it because its raining (no wipers) and found a kill switch that looks professionally fitted in the passenger footwell and a button under the steering wheel that turns the electrics on until released again πŸ™„... nobody has a clue why they have been fitted
Post #612420 12th Nov 2021 3:56pm
Two things, l doubt heavy rain caused your problems, flooding yes- heavy rain no. Particularly as you appear not to have found any water in the car. Have you checked all the carpets for water/ damp?
Secondly, the button under the dash. You say it turns on the electrics until released. Does that mean with the button pressed in everything on the car returns to normal for the duration?
Post #612424 12th Nov 2021 5:03pm
Spilly1978
The rear lamp was half full of water ,,, immersing one of the bulbs .... would this not be enough to cause harm ? .
And Jo the button when pressed will turn on only the things that are actually working..
Post #612427 12th Nov 2021 5:29pm
Spilly1978
What would be the cheapest diagnostic tool to reset transport mode? I'm trying to sell my range 😩.... baby forces sale and all that πŸ™„
Post #612429 12th Nov 2021 5:31pm
Do all the external lights still work? Including brake lights.
Post #612430 12th Nov 2021 5:42pm
Spilly1978
Yes all lights except interior work ,
Post #612435 12th Nov 2021 6:38pm
Can't think of any reason why your rear light filling with water would cause your problems then.
Post #612438 12th Nov 2021 6:46pm
