Home > Technical (L322) > Trickle charge through tow bar plug
MartinD
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Did a search in here but couldn't find anything conclusive; is there a wiring diagram (or even a pre built cable) for those who've done the trickle charge-via-tow-bar socket? 2011 4.4 TDV8 Vogue SE - 'Black Betty'
2000 4.0 P38 HSE - 'Green Goblin' - Gone.
Audi..Mini..BMW..
Post #612444 12th Nov 2021 8:01pm
mjdronfield
It’s in the site shop,
https://fnltd.co.uk/shop/tow-electrics-cha...c-p45.html
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #612445 12th Nov 2021 8:05pm
mjdronfield
Or do you mean the bit on the car? I can’t help with that I’m afraid.
Towists will be along soon….. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #612446 12th Nov 2021 8:07pm
MartinD
That's the one, thanks Smile 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #612447 12th Nov 2021 8:12pm
Fox889
I bought the 13 pin adaptor, really nicely made. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #612490 13th Nov 2021 9:33am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
I find it so easy, boosting the charge by this method Thumbs Up
Post #612497 13th Nov 2021 11:07am
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Shame I cannot get any connectors for my NOCO because it's the 15000.
They only sell the connectors for the smaller ones. NOCO don't sell them either Christian.
Current Cars
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #612501 13th Nov 2021 12:25pm
mjdronfield
Can’t you get one and change for your needs?
Aren’t there just 2 wires used for this?
Or is there something more clever going on…..
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #612502 13th Nov 2021 12:42pm
Caesium
I've made one up using a connector and some flex, on the charger end I have used two bolts through a piece of wood as power posts to connect the croc clips up.
My NOCO has a huge connector in the middle of the charge leads as it has a 20 amp boost charge so I cannot get a spare connector to wire it in properly just using connectors.
the CTEK I had before had a much smaller connector plug so that would have been easier but I needed to buy the NOCO to charge my M4 up (lack of use) as it has a Li-Ion battery and requires a specific charger Christian.
Current Cars
2019 BMW X4
or
Post #612504 13th Nov 2021 12:50pm
mjdronfield
Ah… things have moved on a bit then….
My M5 didn’t even have traction control 🤣 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #612505 13th Nov 2021 1:05pm
Baltic Blue
I made up this board so that I could use a charger with crocodile clips or my Ctek.
Post #612507 13th Nov 2021 1:28pm
misfire84
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
I just use a ctec charger via a 10a fuse the a 13 pin trailer plug and it works fine .. i plug it in if the RR is not going out for a couple of days also keeps the battery toped up so the FBH works when it gets cold enough for it to be needed . 2012 Black 4.4 TDV8
1968 Mgb Gt
Post #612508 13th Nov 2021 1:36pm
