Home > Technical (L322) > Water leak
Tdtj
Scotland 2016 Range Rover Autobiography SDV8 Santorini Black
Water leak
Good evening everyone
Well 7 weeks of ownership and still pleased with the car. However as per title I have water leaking and investigating this afternoon I found I have a broken piece which goes from the top hose into the valley
It’s the join piece that goes from the small pipe to the 90 degree piece which leads to the top hose
Obviously 5pm on a Saturday no chance of getting said piece
Just wondering if anyone knows what I should be asking for when I get to the parts department
Thanks in anticipation
Post #612521 13th Nov 2021 7:19pm
RJPotts
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
It might be worth filling in the vehicle on your profile, or mentioning it alongside a question re model-specific parts?
See Microcat. The number it will give you will be a reference number, usually googling that + 'Range Rover' will get results. If not, then scroll down the Wiki, open the Russian microcat, find the same part on there and when you click on it you'll get a screen showing part numbers within the URL. 2010 Range Rover Autobiography TDV8 Santorini Black
2010 Range Rover Autobiography TDV8 Zermatt Silver [Gone]
2003 Range Rover HSE Oslo Blue [Gone]
1985 Camel Trophy 90 (Netherlands Team Vehicle) [Gone]
1990 Camel Trophy 127 (Workshop Vehicle) [Gone]
1989 Camel Trophy 110 (Workshop Vehicle) [Gone]
1998 Camel Trophy Freelander (South African Team Vehicle)
1995 Camel Trophy Discovery 300Tdi (Raft Unit) [Gone]
Post #612531 13th Nov 2021 8:16pm
MartinD
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Re: Water leak
Out of interest and only slightly off topic, who are you using for servicing/repairs? 2011 4.4 TDV8 Vogue SE - 'Black Betty'
2000 4.0 P38 HSE - 'Green Goblin' - Gone.
Audi..Mini..BMW..
Post #612535 13th Nov 2021 8:22pm
Tdtj
My sincere apologies I thought my signature was already filled in
It’s a2011 tvv8
Post #612554 13th Nov 2021 10:32pm
Tdtj
I’m not using anyone just now as I’ve only had it seven weeks
Any recommendations would be very much appreciated
Post #612555 13th Nov 2021 10:34pm
RJPotts
-Incorrect link removed by poster- should I think be the page. What's the item no on there for the hose you mean? 2010 Range Rover Autobiography TDV8 Santorini Black
Post #612556 13th Nov 2021 10:36pm
Tdtj
Thanks mr Potts
Its more of a join piece that goes on one of the thin pipes from the four piece top hose but the bit that goes from their before it goes into the valley. If that makes any sense 2016 4.4 diesel
Post #612558 13th Nov 2021 10:41pm
RJPotts
Ah, 2011, will be a 4.4 presumably?
Does the picture on this link look familiar? https://allbrit.de/epc.cfm?PAGE=3030305A-T...SPRACHE=EN 2010 Range Rover Autobiography TDV8 Santorini Black
Post #612562 13th Nov 2021 11:01pm
Tdtj
Yes sir it is and yes the picture is correct also
Its the pipe 8260b but not the whole top hose
Its the bit that connects the little hose that the arrow is pointing to that connects with the other little pipe into the v bit I need
Its a plastic piece not rubber. Its looks similar to a spinning top but with longer ends
If you can see where the line goes into the other hose. Its the bit that is actually sticking out of the other unit 2016 4.4 diesel
Post #612583 14th Nov 2021 9:06am
Tdtj
 2016 4.4 diesel
Post #612597 14th Nov 2021 11:48am
rjff
I think you'll find the part you refer to is only available as a whole assembly. It was about £84 two years ago.
Comes with two large hoses, 4 way conector etc.
Beware that the end into the fitting the arrow is pointing to requires care to remove as force will break the lower part of the fitting resulting in another large bill for an assembly!
You could use a temporary pice of pipe and hose clamps in place of the fitting, assuming my interpretation of your leak is correct. You may be able to source just the connector fitting on ebay if you can determine its dimensions.
HTH Cheers
Richard
Gap IIDBT
Post #612598 14th Nov 2021 11:50am
Tdtj
Thanks for your reply
Bit of a pain to buy a lot of stuff just for the sake of a fitting
Mmm and you can’t really see if you have broken anything further down the line until filling with water
Is it the oil cooler that it leads to
There’s a lot of stripping out to get under where it leads 2016 4.4 diesel
Post #612604 14th Nov 2021 12:02pm
rjff
You'll find it goes to the thermostat housing, which comes with several pipes attached.
Download the WM for the 2011 from the Wiki and have a read over the section on cooling. It's fairly good on showing most of the info, and the drawings allow a good idea of where things fit.
If it is the smallcoupling that's leaking on the small pipe by the intake donut then as said a temporary relacement could be made. It's been done by someone on here.
The most ususal leak is on the fourway pipe by the rad, which also is fraglie enough to break when you are changing the donut hoses or cleaning the throttle body/MAP sensor. Cheers
Richard
Gap IIDBT
Post #612609 14th Nov 2021 12:21pm
Tdtj
Ok thanks for the reply
We’ll see how the day progresses lol at the moment it is in two pieces so need to work something out 2016 4.4 diesel
Post #612611 14th Nov 2021 12:28pm
Tdtj
Morning all
So on Sunday I ordered the part that comes with all the hoses attached as in picture in previous replies
Managed to get one from eBay new 43.00 pretty much
It arrived yesterday so fitted just the bit that I needed in about 2 minutes and that was it
It has stopped leaking and it’s building up pressure
So for now think it’s fixed. I’m going to keep an eye on the water level for the time being
Thanks for your help gentlemen. Much appreciated 2016 4.4 diesel
Post #612874 17th Nov 2021 11:04am
