![]() | Home > Maintenance & Mods (L322) > Battery Replacement 2011 TDV8 4.4 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
I think there was a software update that made the message less sensitive. General consensus it that it shows too early and can mostly be ignored.
You can see a bit more of it on the first picture of the thread, the black plastic cable covers/pipes clip into it. I assume the sponge is to stop it rattling.
RRover Member Since: 17 May 2021 Location: Sussex Posts: 278 ![]() ![]() |
Cheers for that - makes full sense! |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3380 ![]() ![]() ![]() |
This is on my list of jobs but so far the existing battery refuses to give up. Can the IID tool show the battery age or condition? 2012 TDV8 Vogue (L322) |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 358 ![]() ![]() ![]() |
The engine start on my 2011 5.0 S/C had been gradually been sounding slower and slower in the recent cold spell, until one day it wouldn't turn over at all. To be fair, I think it still had the original 10 year old Land Rover branded battery, in which case it's lasted very well!
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1015 ![]() ![]() ![]() |
I think it's for detecting if the bonnet is securely pushed down, if it's not a warning message appears on the in dash screen |
there is a video somewhere, I will look for it, the bonnet sensor in this photo, to the right of his left hand
The bonnet switch is on the other side. Not sure what that flap is. 2012 TDV8 Vogue (L322) |
Agreed, my bonnet sensor is on the other side (and I did replace it a few months ago as it was intermittently operating and setting off the alarm, especially on sunny days!).
SNDa180 Member Since: 07 Mar 2022 Location: Surrey Posts: 3 ![]() ![]() ![]() |
A very helpful thread. Would anyone be able to explain what the various positive cables (ie red ones) lead to and which should be where? In changing my battery, it’s apparent there’s been some inventive amendments where two cables are running of the one terminal bolt, when they shouldn’t be. |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 306 ![]() ![]() ![]() |
Would you be able to post a photo ? TDV8 4.4 2012 |
I'll take some pics tomorrow morning before I set off on my job if it helps? 2012 TDV8 Vogue (L322) |
tintin1100 Member Since: 23 May 2022 Location: somerset Posts: 2 ![]() ![]() ![]() |
brilliant thread this...made the battery change so much easier. Thanks |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200 ![]() ![]() ![]() |
Totally agree re coverage on here making it a straight forward task. Having the the correct tool to remove the security bracket as mentioned here is a must and the tip to remove the pollen filter assembly first is the way to go giving more room in restricted space.
