Home > In Car Electronics (L322) > What are people doing for BT Audio in 02-05 sound systems?
conor
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
So guys,
I'm going to make the assumption that I can't just pair my phone up to my 02-05 Supercharged L322?
So..
The above is also true for my 2004 Mercedes SL. For the SL I have used this Anker Bluetooth audio adapter which is really cool. The sound is pretty good.
Off the bat, I can see myself buying another of these for the L322.. from a quick google I can see that people are using the aux in of the RSE as the input (thankful I have that).
One of the biggest drawbacks of the system is that I can't keep it on charge when it's running, as I get a nasty ground loop noise on the audio. I tried one of these filters but the resultant audio was garbage.
It's not a bad solution and I think I would be happy with it.. I think some time I would like to be able to wire it up somewhat more permanently so that it comes on/off with the ignition and also I can filter out the ground loop while keeping the good audio quality.
Interested to hear what others are using.
Cheers
Conor
Post #612577 14th Nov 2021 2:31am
Matt Buckland
United Kingdom 2017 Range Rover Autobiography TDV6 Santorini Black
I have a 2012 Westminster, but I use the Amazon Alexa auto for music. Wired to the aux socket and powered by USB, BT linked to phone (and phone also BT linked directly to car as normal).
It is a great solution, as apart from being able to control home automation from within the car, it allows me to stream music, take calls, etc. the voice control of Alexa is much more advanced than the OE voice command in the Rangie.
I guess the only drawback is that music streaming is limited to Spotify or Amazon music (so won’t stream songs loaded on my phone), but in reality I generally play radio stations on Alexa, so I’m okay with that.
Echo Auto | Add Alexa to your car https://www.amazon.co.uk/dp/B078YP59TT/ref...R1AJCDDABV L460 460e PHEV AB. Belgravia green.
Previous toys:
L405 2017 TDV6 AB
4.4 TDV8 Westminster. Santorini Black
1976 Lightweight
4.0l P38
2 Disco 3s
Jaguar XJ6 (X350)
Jaguar XJ8 (X308)
Jaguar XK
Jaguar XK8. Confirmed JLR nut.
Post #612591 14th Nov 2021 10:29am
Anvil
I think it may be your ground loop isolator Conor? I use one on a cheapo Ebay bluetooth reciever and it works well for me. https://www.ebay.co.uk/itm/392734699305 FFRR 4.2SC/KTM 990SMT Current and cherished.
Honda Accord 2.4 Vtec touring. (Yeah, I know, think: Kids)
Mitsubishi Pajero Evolution Nut-wagon. and a Buell XB12R
TVR Griffith 5.0 (backed up with Vauxhall Carlton road barge for the weekly shop.)
Honda Integra Type R DC2 Possibly the best drivers car. Ever.
Mitshibishi FTO GPX MIVEC.
Honda CRX Vtec Mk2 -NO, Not the del sol!!!
Volkswagen Scirocco GT
Mini 1275GT
MG Midget (Heavily modified)
I'm going to stop now.....
Post #616471 15th Dec 2021 1:04pm
conor
Yeap.
Out of the box there is a ground loop.. I bought a cheapo one from Amazon and while it did remove the ground noise, the sound from it was terrible.
I guess I need to just get a higher quality isolator.
Post #616481 15th Dec 2021 1:58pm
Anvil
Hi Folks, I just posted what I have done in a similar thread. https://www.fullfatrr.com/forum/topic61372-45.html
Hope its of help.
Si. FFRR 4.2SC/KTM 990SMT Current and cherished.
Mini 1275GT
Post #616488 15th Dec 2021 2:43pm
dhallworth
Although yours is an 05 registered Supercharged it'll be based on the later architecture of the 06MY with the touchscreen so don't get the two systems confused as they're very different.
There's a 3.5mm socket behind the centre cubby box, I use a male to male 3.5mm cable and plug it into a battery operated bluetooth receiver. Works very well and only cost a few quid to sort. Make sure you're using a shielded cable though.
Post #616501 15th Dec 2021 4:19pm
muddycharles
United States 2008 Range Rover HSE 4.4 V8 Bonatti Grey
I went down this road
https://www.fullfatrr.com/forum/topic58324.html
Works well 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #616723 17th Dec 2021 2:24pm
conor
David.
Hi David, thanks for that.. i've been having a tough time dissecting what it is that I have, so thanks for pointing that out. I knew that my exterior setup was from the 06MY but wasn't sure about the interior/electronics.
So... is it the case that while the general interior etc didn't get refreshed until a little later, but the entertainment system was updated.
Hope its of help.
Si.
That's a great setup Anvil and I like it a lot - may I ask when aux input you refer to/use in your setup? Is it the one towards the rear of the centre console i.e. in the rear, facing the rear passengers... as opposed to some other location I've not seen? Thanks a lot!
Works well
Thanks Muddycharles, it looks like a solid solution alright I might try out as a first port of call, prior to any cable hiding solutions..
Thank you kindly.
Post #617850 29th Dec 2021 2:02am
Anvil
Yep that’s the one. Facing rear passengers. Get a 90degree plug to it doesn’t stick out. Loads of them on eBay. FFRR 4.2SC/KTM 990SMT Current and cherished.
Mini 1275GT
Post #618097 31st Dec 2021 1:19am
Danwilderspin
If you’ve not got rear screens just gut it and go after market. Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #618932 6th Jan 2022 12:51am
conor
Cool, thanks for the headsup. Also, Anvil - notice you have a ground loop isolator in your setup there? It looks like the same one I had, and the sound was crap through it.. how do you find yours?
I have RSE, why does it make a difference..? Is it because you would lose all your RSE. In any case, when you go aftermarket, don't you lose all the OE software in the ICE system? I'd like to keep that.
Post #619164 8th Jan 2022 12:51am
Danwilderspin
yea you'd lose it. I upgraded everything except the speakers as they are pretty good with a decent 6 channel amp. go hard or go home with that setup Smile Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #619202 8th Jan 2022 2:52pm
Anvil
Hi Conor, I found it reduced volume just a little bit, but the quality is ace. No feedback and still great bass, treble and mid range. Still have all the rse in mine too! FFRR 4.2SC/KTM 990SMT Current and cherished.
Mini 1275GT
Post #619288 9th Jan 2022 12:47pm
conor
Ok, thanks a lot for that.. do you happen to have a link to the item you bought? I'd be curious to check it out.
Thanks a lot.[/quote]
Post #619407 10th Jan 2022 1:31am
Anvil
Hi, the exact link I used on Ebay has expired, but this looks to be similar and a similar price: http://www.ebay.co.uk/itm/Ground-Loop-Nois...2171319d08 FFRR 4.2SC/KTM 990SMT Current and cherished.
Mini 1275GT
Post #619451 10th Jan 2022 1:39pm
