![]() | Home > My Range Rover > My L322 Project |
| Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454
All my fluids are nearly done now with the exception of the engine oil which was done in June by previous owner and I intend on doing in December, the next one to tackle is the transfer case.
As you may have seen from my first post, the tailgate needed some attention before the rust created a hole and with winter approaching I made it a priority to get done.
Headlight bulbs.
| briangunn Member Since: 19 May 2019 Location: London Posts: 56
Great work, and you're reminding me that the HID bulbs on my facelift 3.6 (with the same lights) are a bit pants, so I'll get some new bulbs as they'll be the originals. The LED lights for the main beams look good too. |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3348
That’s a big improvement. Have you got a link to the bulbs you used? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Both the bulbs I got from Amazon.
| rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 569
Beam pattern looks wrong, where is the kick up to the left side to illuminate kerbs? Have you got it set to continental pattern by any chance? Drives:
I have never checked the lever to change the driving mode, I'll do that!
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
up for UK, down for euroland.. |
Now rvbush has started me off! I cant see the beam pattern in the daytime and I have just fiddled with the levers which were both in the upwards position, but that shows a flat beam pattern (as per the photos).
My front door speakers have blown (the spider has detached from the frame) so any bass sounds like a load of loose paper flapping about.
Took the RR up to North Norfolk for a few days and she performed brilliantly, her first long distance and everyday use test since I got her.
That's a good result on rebuilding the prop.
| All times are GMT |
