![]() | Home > Technical (L322) > P040D and restricted performance 4.4Tdv8 … red herring?? |
Smitch Member Since: 05 Oct 2021 Location: North west Posts: 40 ![]() ![]() ![]() |
Looks to me like they have been blowing this is the underside of the hoses and I got a good handful of soot/oil of one of them before taking the pic :/
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
The only time I had a RP fault it was these hoses. No particular strange noises but very sooty like your. Swopped to silicon and the problem went away so highly likely this will solve your problem, especially if oil seals have been done as hoses will all have been moved/bent/twisted to do that.
I did consider just getting a new plenum but the seam split is not too common and as you said the price is high, I will check it over though.
Thaaaar she blows!!!!
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Get some nice silicone hoses on there and you should be good |
