![]() | Home > My Range Rover > That's better... |
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383
Looking good. White emulsion? Where was the car? In the living room!
| allycraven Member Since: 28 Mar 2011 Location: North Craigo, Angus Posts: 440
looks like emulsion spots |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014
In reality the only way your bonnet will be perfect is with a respray. A good bodyshop should be able to do a perfect match for you, I'd expect to pay £300-£500 though. It's often cheaper if you're having other bits done too.
| pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865
i like them wheels i think they look good if my wheels was mint id be offering a deal.....as for the bonnet if you can find a good painter he should have no problem blending the front in to eradicate the stone chips "RANGEISM WILL NOT BE TOLERATED"
Don't know if a thumbs up on the wheels from an Essex boy is a good thing or not.... |
From horribly bitter experience, they are a useless design if you take them off road, even mild soft roading, I went through three sets on my RRS SC. The problem is they have no protection from the Tyres, so any mud/grit/stones etc just grind away at the surfaces, through ruts etc. Discovery 4 HSE
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35872
i beg to differ lord rruk, i have the same wheels on mine and they done me proud on the salisbury plain trip..
Y. O. L. O. . |
| BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429
scarey - your tyres look like the proper size for a fullfat compared to ally's picture
they are much bigger and wider than the normal FF size..
correct - 275/40' are fitted.
if i was a true essex boy id be saying you need some 24" chrome wheels with rubber band tyres or it would be a primark suit with gucci shoes.....its all about the shoes they do look nice maybe some bigger profile tyres would look better "RANGEISM WILL NOT BE TOLERATED" www.futuresecurityservices.co.uk Pretlove says , '' I want my car back |
| Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181
I think both Stormers and the RRS S/C -TDv8 wheels look good on a FFRR, but they do need the higher profile tyres. My Evoque is coming shod with Stylr6 (Evoque) design - my youngest sister just fitted a set of copy style 6 and within a week she has one cracked, two porous and one scuffed. Not worth having them even if they are cheap if they are going to go flat on you after a few days! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
any rim can be kerbed ..as long as you go up/down the kerb slowly you should be ok... ... - .- -. Y. O. L. O. . |
True, but that little extra width and higher profile of the 295's would bring peace of mind. Closer to stock FF 255/55/20 rolling diameter as well...
