![]() | Home > Maintenance & Mods (L322) > Completely seized wheel nut |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3391 ![]() ![]() ![]() |
Heat + impact driver. If a 12 point socket rounded it off use a 6 point. 2012 TDV8 Vogue (L322) |
Tattiepicker Member Since: 01 Apr 2021 Location: Aberdeen Posts: 51 ![]() ![]() ![]() |
None fit anymore I’m afraid. Not sure if I recovery socket adapter would withstand the torque that is on it to remove. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35868 ![]() ![]() |
this kind of situation is a pain....i would find an old impact socket which is slightly smaller than this nut and bang it on with a hammer...then either a breaker bar or high powered impact wrench to try and shift it..good luck. ... - .- -.
Seized nuts and bolts respond better to impact than torque IME (torque has obviously failed here). You need to send shock waves through the nut to break the friction.
Cheers Stan, worked a treat. Thought I was going to snap the threaded bolt
Great news! 2012 TDV8 Vogue (L322) |
Sacrificed a brand new 20mm socket though 🥲 |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
Cheap for what it could have cost |
nice job Matt.. |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1586 ![]() ![]() |
Thank goodness it wasn’t a locknut! Ron B. VK2OTC
